I was told awhile ago that Navision will be going .net.
I'm looking for more information on this. When they say going .net do they mean we will be using a .net language for development. Like C# or possibly CAL.net? Will we be using visual studio for development?
Which version is this meant to be happening in?
I really have no clue so any links or information to point me in the right direction would be apprechiated. Thanks.
Possibly web enabled will be something like how Oracle and JDE works where the user uses a broswer to access the application? Making easier to allow users to access the application from remote sites. I doubt that though as Windows Forms applications are alot more user friendly. But it could be something like that.
Ok, thats good to hear then.
Know anywhere I can find more information on it? I've tried searching around but not had much luck.
If you have access to partnersource, there are some powerpoint presentations available there, for partners only.
That was an awesome day in Seattle wasn't it Kamil \:D/
RIS Plus, LLC
MVP - Business Apps
Yes, it was. There are some pictures from there...
http://www.darkzone.cz/~ksacek/seattle2/index.htm
of course, nothing under NDA 8) ...
But more and more I can see, that others know many secret things... I am looking forward the discussion about Dynamix Nav after MS will publish the informations...
Do you have a link?:) I can't find it on PartnerSource :oops:
Best Regards
RIS Plus, LLC
MVP - Business Apps
RIS Plus, LLC
MVP - Business Apps
I was doing some reading yesterday on Navision 5.0 and that it will become a 3 tier application as apposed to the 2 tier client/server model its using now.
Someone in this thread also said that Nav 5 will be using a new gui. Something about windows forms. Anyone know how we will go about developing these forms? I don't see a point making a new editor for windows forms for just 1 version of Navision when by version 6 its going to use visual studio. So I was thinking will we be using visual studio for form editing in version 5? If so does that mean there will be some type of new integration between external programs and Navision working together?
Of course, as you can see in SP1 for 4.00, Navision is trying to be able to integrate into other applications. If you know more about "green" target, you know what is the final form of Dynamix.
In which case if we are using Windows Forms as the GUI for the application currently there is no way to call a piece of code in Navision from an external program (that I know of) which is what the windows form would be. So does this mean in version 5.0 we can expect some new type of functionality to allow external programs to call code within a Navision object say to validate data entered into the form or call a codeunit due to a button press on the form.
