Problem with OnInputChange() Trigger
ajaybabuChajaybabuCh Member Posts: 208
I have one text box bounded to the variable 'Search Name' of type Text.
As the user enter the text in the text box I want to filter records.
I can not get the text as the user entered into the Variable 'Search Name'
in OnInputChange Trigger.
I tried the following code to get the text
OnInputChange()
CurrForm.SAVERECORD;
RESET;
REC.SETFILTER(FieldName,SearchName+'*');
Whenever the user enter the single character that will be blocked with blue color.
To enter remaining text I need to click on the control and move the cursor to the end of text then only I can enter the text other wise it will be replaced with new character.
How to get the text entered by the user as it is in the OnIputChange() trigger.
AJAY INDIA.
Ajay
    Use SENDKEYS for that, and send in F2 twice. I don't exactly how to do this, but one of my coworkers got that to work. You should be able to search for sendkeys in this forum.
    Thomas_Hviid_ThornThomas_Hviid_Thorn Member Posts: 92
    Hi DenSter,
    could your (or others) provide a little more information: I have been asked to make the same functionality, but has problems getting back into the TextBox and let the user continue typing.
    I've made the following code:
    GetKeys is the automation 'Windows Script Host Object Model'.WshShell
    SearchNameBox is the name of the TextBox
    SearchName is a Text250
    Text1 is a field on the table
    CurrForm.SearchNameBox.ACTIVATE;
    IF ISCLEAR(GetKeys) THEN
      CREATE(GetKeys);
    GetKeys.SendKeys('{F2}{F2}');
    RESET;
    SETFILTER(Text1,searchname+'*');
    but it lets me only enter one char!
    With Kind Regards
    Thoms Hviid Thorn
    David_CoxDavid_Cox Member Posts: 509
    OnInputChange()
    RESET;
    Just move your first code to the OnAfterValidate trigger of the textbox
    OnAfterValidate()
    RESET;
    REC.SETFILTER(FieldName,STRSUBSTNO('%1%2%3%2','@','*',SearchName));
    CurrForm.UPDATE;
    The @ means Ignore Case
    If that still has problems then create a function on the form and call this! :)
    Analyst Developer with over 17 years Navision, Contract Status - Busy
    Mobile: +44(0)7854 842801
    Email: david.cox@adeptris.com
    Twitter: https://twitter.com/Adeptris
    Website: http://www.adeptris.com
    Hi David.
    the reason to use the OnInputChange was to get the 'Find-As-You-Type'-functionality, as known from the Find (Crtl-B in ENU language).
    Below the field the information which is searched in is filtered, so you're immidiate see the result of the filter (without pressing Enter).
    ... as you all may guess - in Denmark its summertime, and the boss is on holiday ... :D
    With Kind Regards
    Thoms Hviid Thorn
    Oh yep! :oops:
    I did not read the original post correctly!
    The text is left selected after entering one value, so find as you type is not working.
    Would form or control update or control activate solve it?.
    currForm.UPDATE;
    currForm.MyControl.UPDATE;
    currForm.MyControl.ACTIVATE;
    That's ok, David - glad you reacted so fast.
    Sorry - no, that still move focus away from the TextBox.
    With no luck, I've tried to track down the uppersite SENDKEYS-method.
    Guess, I've just have to wait for NAV 5 and Visual Studio ...
    With Kind Regards
    Thoms Hviid Thorn
    Are we gonna be beaten by this one?
    One last untested Idea, Use a form with the search variable, and a sub form with a form function to filter and update the lines.
    On the parent form OnInputChange call the subforms function with the SearchString, and get a customer No. returned, without updateing the parent form!
    Duh!! Reverse Gear! this won't work as we need to return a record!
    Back to the think tank!
    ajhvdbajhvdb Member Posts: 672
    Can't you put the databasefield on the form and make it uneditable. Then when typing in this field you can use the standard search.
    OK looks here is a solution I did a while back. I just re did it quickly in 5 min.
    I'm sure you can make prettier. It's based on Item record.
    OBJECT Form 50000 example filter as you type
      OBJECT-PROPERTIES
        Date=06/28/06;
        Time=[ 8:29:31 PM];
        Modified=Yes;
        Version List=;
      PROPERTIES
        Width=9130;
        Height=6820;
        TableBoxID=1000000000;
        SourceTable=Table27;
      CONTROLS
        { 1000000000;TableBox;220 ;220  ;7920 ;5500 ;HorzGlue=Both;
                                                     VertGlue=Both;
                                                     InlineEditing=Yes }
        { 1000000001;TextBox;0    ;0    ;1700 ;0    ;ParentControl=1000000000;
                                                     InColumn=Yes;
                                                     SourceExpr="No." }
        { 1000000002;Label  ;0    ;0    ;0    ;0    ;ParentControl=1000000001;
                                                     InColumnHeading=Yes }
        { 1000000003;TextBox;0    ;0    ;4400 ;0    ;HorzGlue=Both;
                                                     InColumn=Yes;
                                                     SourceExpr=Description }
        { 1000000004;Label  ;0    ;0    ;0    ;0    ;ParentControl=1000000003;
        { 1000000012;TextBox;2640 ;6050 ;2420 ;440  ;Name=box1;
                                                     SourceExpr=Searchtxt;
                                                     OnActivate=BEGIN
        Searchtxt := searchtemp;
                                                     OnInputChange=BEGIN
        CurrForm.box2.ACTIVATE;
        CurrForm.box1.ACTIVATE;
                                                     OnAfterInput=BEGIN
        Searchtxt += Text;
                                                     OnValidate=BEGIN
        searchtemp += Searchtxt;
        SETFILTER("Search Description",'*@'+searchtemp+'*');
        { 1000000013;TextBox;5500 ;6050 ;660  ;440  ;Name=box2;
                                                     Editable=No;
                                                     SourceExpr=Searchtxt2 }
        { 1000000014;Label  ;440  ;6050 ;1870 ;440  ;CaptionML=ENU=write here }
        { 1000000005;CommandButton;6600;5940;2310;550;
                                                     CaptionML=ENU=Clear;
                                                     OnPush=BEGIN
                                                              Searchtxt := '';
                                                              Searchtxt2 := '';
                                                              searchtemp := '';
      CODE
        VAR
          Searchtxt@1000000000 : Text[30];
          Searchtxt2@1000000001 : Text[30];
          searchtemp@1000000002 : Text[50];
        BEGIN
        END.
    I added a button to clear it. Again I did in 5 min. It can be improved. I'll make it better.
    Hi folks,
    No, Find is not good enough - then I wouldn't have asked here!! :wink:
    By now it's only a prototype, just to try if it can be done (as we want it).
    Whether its going to be used or not, will also depend on other issues as performance - which I'll not make a subject here (Others may be welcome though).
    - BlackTiger
    I know ONE way how to do this
    Do you mind sharing ?
    - ara3n: That about where I/we are heading too.
    Thanks for for sharing.
    With Kind Regards
    Thoms Hviid Thorn
    BlackTiger, I'm tempted to dare you - but since I haven't got the money to do that, I'll just back off here :)
    OFF-TOPIC:
    Even it's stupid feature
    Every IDE but C/AL got the feature of for programmers (Find-Statements-As-You-Type) - but I guess you find that stupid too :-s
    As off my point of view, I stand <beaten> aside David Cox.
    With Kind Regards
    Thoms Hviid Thorn
    Hmmm... No. Or for quite good money. Just because it's not realy necessary feature. Even it's stupid feature. And stupid features must to cost alot of money. Also it's not problem of Navision.
    Hmmm... Sad day, :( If we all took this view this forum would close! [-X
    How many questions do we answer, when the soloution is simple, and should be covered by the reseller's training and not us?
    How stupid is a trigger called OnInputChange(), where you cannot return the Input, but the help say's ?
    The C/AL code in this trigger is executed while the user makes entries into a text box. You can use this trigger to check the entries the user is making as he or she enters information.
    :D Never say dare-it-not to a Coder!! :D
    Nice work =D>
    May I ask how you did it :?:
    With Kind Regards
    Thoms Hviid Thorn
    Hopefully v5 will give us more controls of the GUI.
    Joe_MathisJoe_Mathis Member Posts: 173
    I tried for a while to make this work using standard Navision Code but with no luck.
    Like everyone else I can get it to filter and then it comes back to re-activating the field and not being able to continue from the last character entered.
    Has anyone else had any luck with C/AL?
    BlackTiger, from looking at your video it looks as if this is using "with events" like your other demo?
    True? I think that the second version looks much nicer than the first. Good Job. =D>
