NAV 2103 R2 Developer License
wilko1977wilko1977 Member Posts: 2
edited 2014-09-02 in NAV Three Tier
Hi all, I have multiple databases for different countries, do I need a developer license per database, or can I use one license across multiple databases?
    defiant701defiant701 Member Posts: 79
    I'm not sure if I get your question right, but your developer license can be used for different localized versions. If you refer to multi installations or multi tenancy it's also possible to use only one license file. As per all options you'll need to change or upload the license (in various possibilities per installation, database, master, tenant or just in dev environment).
    Kr defiant701
    Debuggers don't remove bugs, they only show them in slow-motion
    LinkedIn
    XING
