RDLC: Table header is not printing for the 2nd table control
tsvtsv Member Posts: 49
edited 2014-08-04 in NAV Three Tier
Hi All,
I am using NAV 2013 R2.
I have two data item in the dataset. i have designed two table control for each data item in visual studio 2013.
The issue is, i have used "GETFILTERS" function in second table header, But it is not printing the filters. its blank.
To check, i tried putting a message box in the "OnPredataitem of the second dataitem. it displayed the correct filter but the same is not printing in the RDLC.
Can anybody help me on this?
with regards,
tsv
