It is currently Sat May 23, 2015 6:25 pm
Post new topic Reply to topic  [ 9 posts ]
 Post subject: How to Insert empty record in XMLPort
PostPosted: Mon May 14, 2012 12:10 pm
Country: Malaysia (my)
I have created a XMLport that can import and export records in text. The XMLport is being called from a report by .export or .import.
I have few different tables in the xmlport, but some of the tables might have empty record, so I need to insert empty line to the text file if the table is empty during Export (it does in dataport). Otherwise during Import, if the empty line does not exist, the XMLport will read the wrong record/text from the file.
Any idea how to insert the empty line to represent the record is empty? Like it does in dataport? :-k
 Profile
 Post subject: Re: How to Insert empty record in XMLPort
PostPosted: Tue May 15, 2012 6:07 pm
MVP Microsoft Dynamics NAV
NAV TechDays 2014 attendee
Country: Iceland (is)
If you have MinOccurs = Once property on an Element you will always get the element exported.
_________________
Gunnar Gestsson
Dynamics NAV MVP
http://www.dynamics.is
http://Objects4NAV.com
 Profile E-mail WWW
PostPosted: Wed May 16, 2012 9:04 am
Hi Gunnar,
Thanks for your reply.
Yea, it only exports the element if the Format is XML, but i need to export text instead :(.
 Profile
PostPosted: Wed May 16, 2012 11:03 am
Then your solutions is to use temporary records and check for the need to install an empty record before you start the export.
_________________
Gunnar Gestsson
Dynamics NAV MVP
 Profile E-mail WWW
PostPosted: Wed May 16, 2012 1:10 pm
Hi Gunnar,
I have already tried to use temp record and insert an empty record to the temp table before export, so the text result is:
1st record xxxxxx
2nd record yyyyy
,,0.00,,
4th record zzzzz
But is it possible to get a total empty line instead? For example:
1st record xxxxxx
2nd record yyyyy
4th record zzzzzz
 Profile
PostPosted: Wed May 16, 2012 1:17 pm
By only using a Text[1024] string in the xmlport and code similar to this
Code: Select all
IF DecimalValue = 0 THEN
  TextValue = ''
ELSE
  TextValue = <Formatted string from all record fields>;
_________________
Gunnar Gestsson
Dynamics NAV MVP
 Profile E-mail WWW
PostPosted: Thu May 17, 2012 6:22 am
Hi Gunnar,
Hmm... I am not sure if we are thinking the same approach? I have make a simple XMLport (as shown below) to try on as my original xmlport has too many tables.
on my XMLport:
Node Name Node Type Source Type Data Source
Root Element Text <Root>
Customer Element Table <Customer>(Customer)
no Element Field Customer::No.
name Element Field Customer::Name
ReasonCode Element Table <Reason Code>(Reason Code)
code Element Field Reason Code::Code
description Element Field Reason Code::Description
amt Element Field Reason Code::Contract Gain/Loss Amount
I have set the table as Temporary.
On each table Export::OnPreXMLItem(), i insert an empty record to the temp table:
IF gReasonCode.ISEMPTY THEN BEGIN
"Reason Code".INIT;
"Reason Code".INSERT;
and i call this xmlport from a report by using xmlport.export
So how do you write the empty line?
 Profile
PostPosted: Thu May 17, 2012 3:35 pm
You remove all elements with the type Field and insert one with the type text. Then create the text value from the record data
_________________
Gunnar Gestsson
Dynamics NAV MVP
 Profile E-mail WWW
PostPosted: Fri May 18, 2012 5:00 am
Thanks for your feedback. That's no point of using XMLport then if that's the case.
 Profile
Users browsing this forum: Google [Bot] and 8 guests
