NAV Easy Security Light (ESL1.14)
edited 2015-06-02 in Download section
NAV Easy Security Light (ESL1.03)
NAV Easy Security Light is an efficient, cost-effective way to maintain security in Microsoft Dynamics NAV, greatly enhancing NAV's security features - perfect for companies with less complex security requirements. Available for both the Classic Client and Role Tailored Client, Easy Security Light lets you manage access controls and security roles through easy to use wizards - without modifying the base objects within NAV, so no merging is required. And Easy Security Light is fully integrated with all the features in the Role Tailored Client, such as FactBoxes and the Action Pane.
NAV Easy Security Light is supplied free of charge from Mergetool.com and Microsoft. The solution can be used with a CRONUS (demo) license or added to a customers license at no charge (from Microsoft and Mergetool.com) The Module that must be added by the NAV Partner is 14123010.
Language Modules for Danish, Dutch, English, French, German, Italian, Portuguese and Spanish are included.
http://www.mibuso.com/dlinfo.asp?FileID=1440
    PerPer Member Posts: 46
    Training video's are available on this page.
    http://mergetool.com/addin_e/faq/FAQ_ESLTRAINING_WEB.htm
    Please give feedback good or bad :roll:
    ajhvdbajhvdb Member Posts: 672
    I've seen your solution.
    While extending our own I have seen how much work it takes to create all these videos, documents, etc.
    Excellent work and respect.
    NAV Easy Security Light (ESL1.05)
    ESL1.05 (Released 2012 6/9)
    NAV 2013 beta version of Easy Security Light is included.
    A Role Center has been added for Easy Security Light.
    Small corrections to the RoleTailored application.
    rinki123rinki123 Member Posts: 367
    Hi Experts,
    I have installed NAV Easy Security Light,but whenever i am trying to run the ESL forms,some permissions related error messages are coming and Under object designer, it doesn’t let me run anything imported with customer’s license.What is the solution of this problem??
    Rinki
    You need to add the Module "14123010 NAV Easy Security Light" to the customer license. This module is delivered from Microsoft and Mergetool.com at 0 cost. Just ask your partner to add the module.
    You can also use the application with a CRONUS license. That does not require an updated license.
    The complete application is for free, except the recording of permissions are limited to 1..50|10000..99999 with the free edition, With a registration process is done from inside Easy Security Light.
    Is there a negative permission tool? That is more realistic. We do not know what people do. But we know what they shouldn't.
    I.e. everybody is at first a superuser. Then the CEO says OK take away looking at Chart of Accounts from people. Then 1 month later he says OK now take away something else.
    Do I need to manually write programs to generate "all tables except y" permissions?
    @Miklos:
    The Easy Security Light product only deal with the TableData permissions and what you describe is hard to do. But take a look at he Object Level Security with the full version of the video explains how this works.
    http://www.youtube.com/watch?v=0lQc6TCiuH0
    NAV Easy Security Light (ESL1.07)
    ESL1.07
    A new report has been added that can be used to verify the number of tables used by any process in Microsoft Dynamics NAV. By using this process can a process be verified so only the proper number of tables are changed by the process. This YouTube video http://www.youtube.com/watch?v=gxYqhtEskj0 show how this is used.
    A button on the Security setup was not clued properly, this has been corrected.
    NAV Easy Security Light (ESL1.08)
    ESL1.08
    Additional information like Server Name, Database Name and License Number has been added the to the Security Setup.
    MenuButtons now has an image in the RoleTailored Client. This has changed several pages and the forms has got a new version list.
    Very long table name could cause an error. This has been corrected.
    Copy Access Control was not working properly in NAV 2013. This has been corrected.
    ESL1.07
    NAV Easy Security Light (ESL1.09)
    ESL1.09
    The default MenuSuite for Easy Security Light is now 53 and 1053. If previous default MenuSuite (51 and 1051) was imported should they be deleted before upgrading.
    The MenuItems added by Easy Security Light can now be found in the Administration menu too.
    The import of SQL Profiler traces could fail if very long lines existed. This has been changed.
    The order of the fields in the registration has changed.
    NAV 2013 Only: Some field has been extended to 50 characters to accommodate the longer User ID in this version.
    NAV 2013 Only: Language modules has been added for all countries released.
    ESL1.08
    ESL1.07
    NAV Easy Security Light (ESL1.10)
    ESL1.10
    NAV 2013 R2 version has been included.
    The included objects for Limited User counting has been updated to match the current rules from Microsoft.
    ESL1.09
    ESL1.08
    ESL1.07
    FirlionelFirlionel Member Posts: 1
    Per,
    Thanks for showing a simple (or at least a lot simpler) way to manage user security in NAV. I have one quick question though: is there a possibility to limit user viewing access to specific ranges within the G/L with Easy Security Light?
    For example, I want users to be able to select certain turnover accounts in sales orders, but I want to limit their access so that they are unable to view i.e. current bank account totals or the company owner's income tax payments.
    I am very happy to have found your tool and look forward to fighting for the full version purchase in our upcoming budget meeting.
    Kind regards
    Robert
    NAV Easy Security Light (ESL1.12)
    Videos:
    Install and Setup of NAV Easy Security Light
    Registration of NAV Easy Security Light
    Maintaining Users with NAV Easy Security Light
    Maintaining Permission Sets with NAV Easy Security Light
    Recording Permission Sets with NAV Easy Security Light
    Using Snapshots with NAV Easy Security Light
    ESL1.12
    ◾Add Access Controls has been added to the Login lists.
    ◾NAV 2013 R2 only: The code caused some compile warnings with obsolete tables being used. This has been corrected.
    ◾NAV 2013 and later: A few images was added in some pages.
    ◾The structure of the code has been cleaned up in a table.
    ESL1.10
    ◾NAV 2013 R2 version has been included.
    ◾The included objects for Limited User counting has been updated to match the current rules from Microsoft.
    ESL1.09
    ◾The default MenuSuite for Easy Security Light is now 53 and 1053. If previous default MenuSuite (51 and 1051) was imported should they be deleted before upgrading.
    ◾The MenuItems added by Easy Security Light can now be found in the Administration menu too.
    ◾The import of SQL Profiler traces could fail if very long lines existed. This has been changed.
    ◾The order of the fields in the registration has changed.
    ◾NAV 2013 Only: Some field has been extended to 50 characters to accommodate the longer User ID in this version.
    ◾NAV 2013 Only: Language modules has been added for all countries released.
    ESL1.08
    ◾Additional information like Server Name, Database Name and License Number has been added the to the Security Setup.
    ◾MenuButtons now has an image in the RoleTailored Client. This has changed several pages and the forms has got a new version list.
    ◾Very long table name could cause an error. This has been corrected.
    ◾Copy Access Control was not working properly in NAV 2013. This has been corrected.
    ESL1.07
    ◾A new report has been added that can be used to verify the number of tables used by any process in Microsoft Dynamics NAV. By using this process can a process be verified so only the proper number of tables are changed by the process. This YouTube video http://www.youtube.com/watch?v=gxYqhtEskj0 show how this is used.
    ◾A button on the Security setup was not clued properly, this has been corrected.
    ◾NAV 2013 beta version of Easy Security Light is included.
    ◾A Role Center has been added for Easy Security Light.
    ◾Small corrections to the RoleTailored application.
    ESL1.14
    ◾The Limited User calculation is not using the tables added until October 2014.
    ◾NAV 2013 and later: One of the FlowFields was not calculating correctly in the Role Center. This has been changed.
    ◾NAV 2015: The function to submit a registration with e-mail was not working properly. This has been corrected.
    ◾The SQL Profiler template for SQL 2014 was not correct and did not allowed filtereing on the database name. This has been corrected
    ◾New written documentation for NAV Easy Security Light has been added. Please refer to the Online Help files.
