Navision 4 On a row v1.02
edited 2013-03-11 in Download section
Navision 4 On a row v. beta093
4 on a row, Navision Financials/ Attain Game.
This is a beta version off one game we a missing in Navision
Have FUN :o
I am working on the Lan version, if you have comment to the game or other thing, feel free to contact me.
http://www.mibuso.com/dlinfo.asp?FileID=423
    eromeineromein Member Posts: 589
    I looks amazingly cool!!!
    "Real programmers don't comment their code.
    If it was hard to write, it should be hard to understand."
    Navision 4 On a row v1.00
    4 on a row, version 1.00, Navision Financials/ Attain Game.
    Have FUN :o
    If you have comment to the game or other thing, feel free to contact me.
    Navision 4 On a row v1.01
    4 on a row, version 1.01, Navision Financials/ Attain Game.
    Have FUN :o
    Version 1.01:
    Minor bug fixed!
    pedroccdapedroccda Member Posts: 90
    It's very nice regarding the idea and the graphics... :D
    but it's too slow using hard :oops: :oops: becouse you test all possible combination... instead using AI tecnique (classic for computer player in game implementation) or almost dynamic programming tecnique (working with graph etc...) ? :shock:
    If I have some time to spend ( :?: :?: :?: ) I'll post you a new version using this tecnique....
    Kiki
    I have also notice a bug. When computer win the color of computer and user are inverted...and this is not a problem...but also the messege about the winner is wrong! I win and the message says that computer win!!!
    Probably it's due to an uninitialized variable in the procedure startgame (I think Color giving a short look at the code) becouse at button press (1-7) Col(1,Player) is executed and the message depend on it:
    IF Color THEN
    MESSAGE(Text003,PlayerName)
    ELSE
    MESSAGE(Text003,VsName);
    It's another thing I want to adjust...always if I find some time to spend...
    Kiki
    I solved the problem regarding the previous described bug. I think there is no problem if a post the new version (1.02)
    The new version is now ready. How can I post the file?? Is it possible??
    Changes are reported here (between the comment lines). The most important is "Player := TRUE;", but also the others are not bad. :)
    NewGame - OnPush()
    StartGame;
    CurrForm.NewGame.ENABLED := FALSE;
    // Pedrocchi Dario
    WeGotAWinner := FALSE;
    CurrForm.VPlayer.EDITABLE := FALSE;
    Player := TRUE;
    // End of Pedrocchi Dario
    IF HostGame THEN
    Yourturn := TRUE;
    Kiki
    May I suggest you contact the author directly? You find his e-mail address on the download page.
    FlemmingDKFlemmingDK Member Posts: 5
    Any finding a bug, fell free to contact me.
    If you can change the AI code to make it faster and better, it be nice =D>
    New version 1.02 is on it way, with the fix from Pedrocchi Dario
    \:D/
    Best regards
    Flemming R. Petersen
    Denmark
    4 on a row, version 1.02, Navision Financials/ Attain Game.
    Have FUN :o
    Peter_KuiperPeter_Kuiper Member Posts: 19
    You might be interested in my version of "Connect 4" as well? You can find it here: http://www.mibuso.com/dlinfo.asp?FileID=1531
    I plaid several games between my program and this one, and I must say my program was faster and was winning. It's only calculating max. 2 steps ahead ("If I do this, can I win for sure at my next move?"), but for the rest it is searching for possibilities and chooses for the move with the most points (based on my criteria). For example, 3 on a row and one empty has more value if below the empty field is another empty field (otherwise the opponent can fill it up easily). Another thing that counts is the even or uneven row. The one who starts will finally get the uneven rows in the last column that will be filled up, and the one who didn't start will get the even rows. This means that the uneven rows have more value for the empty field in a potential line-of-4 for the one who started, and vice versa.
    It is also not giving away its own 'traps' ("If my opponent is doing column X, can I win directly by doing column X as well? If yes, I will not do column X and wait for my opponent to do X...").
    It is also using all historic games: each winning move for a certain position on the board gets (a lot) extra points, and each move for a certain position that ends up losing gets negative points. This mechanism helps the program to improve: you can never win two times in exactly the same way! Try it out!
    Peter
