Database Information in RTC
edited 2012-10-03 in Download section
This page will show you the current database that you are connected to and the current Role Center you are using.
You can change the Role Center by clicking on the name.
To use this page, simply add it to all existing Role Centers.
More information on my blog entries
href="http://dynamicsuser.net/blogs/mark_brummel/archive/2009/11/29/tip-18-nav-2009-rtc-which-database-am-i-logged-into.aspx
and
http://dynamicsuser.net/blogs/mark_brum ... enter.aspx
http://www.mibuso.com/dlinfo.asp?FileID=1159
