Automation
kvbkvb Member Posts: 107
edited 2004-06-10 in Navision Attain
Hi, guys! :D
I have a stored procedure in MS SQL.
I execute it from Navision by using ADO component.
It takes a lot of time to execute it so i need something like Progress Bar.
Any ideas how i can image progress while SQL procedure is running?
Thanx in advance. :?:
    ATACHATACH Member Posts: 4
    xyievo :lol:
    RobertMoRobertMo Member Posts: 484
    if you can measure progress in SQL procedure (like 3 of 7 steps completed) you can make a new table in navision called progress with a PK filed and with text field "SQL status".
    show the "SQL status" on form.
    onopen form start your SQL procedure. in this SQL procedure regulary update your progress table (like 1 of 7 steps completed, 2 of 7 ...)
    on form's OnTimer event just read the progress table...
    of course instead of making "text progress" you can make something more measurable (numbers) so you can show real progrrees bar...
               ®obi
    Thanx, RobertMo.
    Unfourtunately, since my SQL stored procedure begins to execute trigger OnTimer will not run till procedure finished...
    Sorry for my English :roll:
    maybe you can put your call to SQL procedure in OnTimer event itself (and make sure the sql procedure is called only once...)
               ®obi
    Unhelpfull.. :cry:
    kvb
    ti ne ponial? :shock:
    HYIEVO!
    fbfb Member Posts: 246
    How about something like the following:
    CREATE(conn);
    conn.Open('Driver={SQL Server},Server=YourServer,Database=YourDB');
    conn.BeginTrans();
    // options = adAsyncExecute + adCmdStoredProc...
    conn.Execute('sp_LongRunningProc', RecordsAffected, 20);
    StillExecuting := TRUE;
    ElapsedTime := 0;
    TooMuchTime := 300;
    WHILE StillExecuting DO BEGIN
      SLEEP(1000);
      ElapsedTime += 1;
      IF (conn.State() > 3) THEN BEGIN
        IF ElapsedTime < TooMuchTime THEN BEGIN
          ; // do something here to show the user a little progress...
        END ELSE BEGIN
          conn.Cancel();
          conn.RollbackTrans();
          StillExecuting := FALSE;
          MESSAGE('Too much time elapsed.  Transaction canceled.');
      END ELSE BEGIN
        conn.CommitTrans();
        MESSAGE('Transaction completed.');
    conn.Close();
    CLEAR(conn);
    thanks all, it seems to me i got my problem! :P
    My problem is thai i need _ASync_ execution of stored procedure.
    fb, in your code there is a string:
    Can u(or anyone else) say how i can set this params on ADOConnection object in Navision?
    That is what the magic number 20 does in the line:
    KVB
    do u want KASHA?
    srini_shettysrini_shetty Member Posts: 15
    :idea: .... pinga
    There is a little problem again..
    My code was:
    aut_ADOConn.Execute('Consolidation_RequirementForPayment' + '''' + pt_ConsCompany + '''' + ', ' + '''' + pt_BuhCompany + '''' + ', ' + FORMAT(pb_ToCons, 0, 2));
    It worked perfect.
    But as far as i need async execution of procedure i change my code
    (according to fb advice) to:
    , 20);// additional parameter to make async execution
    When i try to compile there is an error in that line. The error message is:
    "A variable was expected. For examle:
    MyVar
    Customer.Name"
    What`s the problem?
    I`m using 'Microsoft ActiveX Data Objects 2.8 Library'.
    The ADO Execute method that allows you to specify async execution requires 3 parameters.
    The method signature (in VB form, see http://msdn.microsoft.com/library/en-us ... xecute.asp ) is as follows:
    connection.Execute CommandText, RecordsAffected, Options
    Your problem is that you are trying to add the 'Options' argument without adding the 'RecordsAffected' argument. To correct this, first create a local variable (let's call it 'intRecsAffected') of type Integer, and then extend your original code as follows:
    ...FORMAT(pb_ToCons, 0, 2)
    , intRecsAffected, 20);  // two additional params for async execute
    Yes! It works :D
    Thanx, fb.
    I need to read the documentation more closely :roll:
    8)
