1) When you are waiting in cash desk queue which move very slowly, you are thinking about some SQL indexes optimalization.
2) If you are ordering some goods over phone, you imagine how they are entering the order into NAV and you will like to know your Customer No..
3) If you are near someone entering orders or receiving payments, you are checking the display if it is NAV or something else...
4) If you go into the hotel reception and you are dreaming about situation, when the youg receptionist will say "sorry, I have some problem with my NAV" and you will answer "ok, I can help you, just tell me what is your problem. I have my NAV license with me and I can correct the problem...".
5) If you ordered some goods and they are late, you are thinking "they are using NAV and the salesman has set some filter excluding my order".
6) If somebody will tell you that he has problems with finding your order and that he must do that and that exactly in this and this way, you imagine that they are using SAP.
My
BLOGNAVERTICA a.s.0
So you're dreaming of NAV? I think that's a sign!
Tino Ruijs
Dynamics NAV Enthusiast
If you go to Denmark this can very well happen. Actually Eric (Waldo) and I were staying in a hotel in Copenhagen last year where they used Navision. Unfortunately nothing broke.
(I've done this a few days ago.)
I do that to accountants I meet.
i do that not only for accountants...
Eric Wauters
MVP - Microsoft Dynamics NAV
My blog
RIS Plus, LLC
MVP - Business Apps
Or press F3 or F4 to add / delete some lines ](*,)
or press ESC to close an window :roll:
RIS Plus, LLC
MVP - Business Apps
Or using applications that have little lookups and press <F6>...
i tried to compile word documentation instead...
compiled succesfully indeed...
My Blog
Sadly I used to do that so often, that I eventually wrote macros in Excel that actually did emulate the F3/F4 to insert and delete Rows. :oops:
13.) you press ALT+F1 in Outlook to hide the Navigation Pane (it works)
RIS Plus, LLC
MVP - Business Apps
RIS Plus, LLC
MVP - Business Apps
It happens with the Escape button a lot too, I'll be doing something totally unrelated to Navision and I tap the Esc button waiting for it to close the application window.
I think it's time for a vacation
My Blog
