Forced Navision Logoff for Inactivity
slowhandfanslowhandfan Member Posts: 56
I have customer who purchased 20 seats running Navision 4.0 SP2
In the stores, receiving personnel are using WINDOWS LOGINS
At the home office, the users use DATABASE LOGINS
The issue is this.. 20 seats is plenty for concurrent access
However, certain job functions in the stores and home office, have people logging onto Navision, working for 5 minutes, and then doing nothing for 5 hours. This effectively takes up 1 seat uselessly..
What he wants is a way to log people off NAVISION if they have done anything for 15 minutes.
He knows how to do this in WINDOWS, but that will not free up the Navision Seat.
DOES ANYONE KNOW A WAY TO ACCOMPLISH THIS.
    install NAS.
    Create a single instance codeunit with timer and let it monitor the session table and delete records (Users) if they are inactive after a certain time.
    themavethemave Member Posts: 1,058
    I also did it with a processing only report on the session table and run it in the job scheduler
    slmaluwaslmaluwa Member Posts: 358
    themave
    I didn't understand the answer. Did it solved the problem?
    I am also desperately looking for a solution for this.
    Currently, I keep one user LOGGED ON forever on the server, in case if we need to login to remove inactive users forcibly.
    Maluwa
    "A bove maiore discit arare minor"-"From the old ox, the young one learns to plow."
    kinekine Member Posts: 12,562
    We are selling to our customers module for that. It is easy to create such a functionality, which will go through Session table and disconnect any inactive user. You can add some setup (inactivity time, skip some users etc.) and you can run it under NAS.
    slmaluwa wrote:
    themave
    Maluwa
    Yes, it is a processing only report,
    dataitem session table
    filter Idle Time > 15 minuts
    this makes it only look at idle sessions,
    then in the onaftergetrecord
    I have the command
    Delete
    that is it
    run it in the job scheduler, so it runs on a regular bases and disconnects idle sessions.
    Does this work if they are running native, or only if the are running under SQL?
    Hello here is an example of single instance CU for SQL.
    OBJECT Codeunit 50025 NAS session monitor
      OBJECT-PROPERTIES
        Date=10/21/07;
        Time=[ 8:03:01 PM];
        Modified=Yes;
        Version List=Mibuso,ara3n;
      PROPERTIES
        SingleInstance=Yes;
        OnRun=BEGIN
                IF ISCLEAR(Timer) THEN
                  CREATE(Timer);
                Timer.StartTimer(6000);
                Db.SETRANGE("My Database",TRUE);
                Db.FINDFIRST;
      CODE
        VAR
          Timer@1004 : Automation "{DDADD7CC-AD56-4CA6-9C85-22AE76BF21A1} 3.0:{E7414D60-2D83-44C7-826A-FD14557299F0}:'CP Timer'.cTimer" WITHEVENTS;
          Session@1000000000 : Record 2000000009;
          Db@1000000001 : Record 2000000048;
        EVENT Timer@1004::TimerEvent@1();
        BEGIN
          Session.SETRANGE("Database Name",Db."Database Name");
          Session.SETRANGE("My Session",FALSE);
          Session.SETFILTER("Idle Time",'>15 min');
          IF Session.FINDSET THEN REPEAT
            Session.DELETE;
            COMMIT;
          UNTIL Session.NEXT = 0;
        BEGIN
        END.
    Here is an example for Native 4.x version and up.
      OBJECT-PROPERTIES
        Date=10/21/07;
        Time=[ 8:15:10 PM];
        Modified=Yes;
      PROPERTIES
        SingleInstance=Yes;
        OnRun=BEGIN
                  CREATE(Timer);
      CODE
        VAR
        BEGIN
            Session.DELETE;
            COMMIT;
        BEGIN
        END.
    To run this from NAS, you need to install NAS.
    Modify CU 1 function
    NASHandler
    Add the following code.
      IF CGNASStartedinLoop = FALSE THEN
        CASE Parameter OF
          'OSYNCH','JOBQUEUE':
            BEGIN
              IF NOT JobQueueSetup.GET THEN BEGIN
                JobQueueSetup.INIT;
                JobQueueSetup.INSERT;
              IF NOT JobQueueSetup."Job Queue Active" THEN BEGIN
                JobQueueSetup.VALIDATE("Job Queue Active",TRUE);
                JobQueueSetup.MODIFY;
              CODEUNIT.RUN(CODEUNIT::"Job Queue Dispacher");
          //Start Mod
          'SESSIONMONITOR':
            BEGIN
              CODEUNIT.RUN(CODEUNIT::"NAS session monitor");
          //End Mod
    Start NAS with startup Parameter SESSIONMONITOR
    it works in navtive, the session table is a navision table, Mine is running on a navtive database
    You can use it in Native if you are using NAV 4.00 and newer. Just in this versions you can disconnect users by deleting their session and you have the Idle Time field there...
    And on SQL you can use it on older versions too, but you need to add the Idle Time into the session view and NAV able or create own session view based on the 4.00 version.
