Please kindly guide me how to install navision 4.0 SP3 in Vista.
I have installed the client with minimum requirement successfully, but it shows an error when trying to open it. :roll:
It shows error as :!:
There are errors in the text conversion (text no. 46-100 does not exist in the .stx file).
Internal error: 47-1
Kindly help me out. :?:
[/code][/url]
http://dynamicsuser.net/blogs/waldo/archive/2007/05/28/dynamics-nav-on-vista.aspx
Eric Wauters
MVP - Microsoft Dynamics NAV
My blog
Thanks, I got hotfix and resolved the issue.
Thanks for ur help.
Please can you provide me the exact web link from where i could get the hotfix for installing navision sp3 on windows vista.
I get the following error
"there are errors in text conversion (text no 46-100 does not exist in the .stx file) internal erro 47-1"
followed by a runtime error.
Please help me out
thanks
I used to face the same problem like you, and finally I found out contacting microsoft support through partnersource by simply telling them what the database version is, you will get the hotfix, because the hotfix is per country version and the file size is quite big and also copyrights stuff, you won't find it directly on mibsuso even tough lots of people want to help you.
This link is what I used before, for W1 NAV 4.00 SP3, but they change the password regularly, so you won't know the extracting password at the end, with support incedent they will provide you the link and password
(http://hotfixv4.microsoft.com/SQL%20Ser ... 86_zip.exe)
Best regards,
MCP - MBS Navision
jle@naviworld.com
Is it possible to post the password for the extraction.
thanks
Normally, you get the password together with the hotfix
Eric Wauters
My blog
That's what I mean, password expires every 7 days for the extraction .When I downloaded it the password was:
Password: e74XR04O
Password Changes On: 10/22/2007
Next Password: oU[wxLYr_
You can try but I don't know the newest password as they change the password regularly, so finally I think it's better to contact MBS support center directly.
Good Luck
MCP - MBS Navision
jle@naviworld.com
the passwords dont work (:-
please..!
