Navision Binary Object File Viewer v1.0.0.27
edited 2004-07-02 in Download section
Simple and straight-forward, and not nearly as advanced as Michael Weigand's fob-viewer, this little application allows you to view .fob and .fbk files.
http://www.mibuso.com/dlinfo.asp?FileID=293
    jhoekjhoek Member Posts: 216
    I have found some minor bugs and performance issues. They will be fixed in the very near future!
    Kind regards,
    Jan Hoek
    Product Developer
    Mprise Products B.V.
    eromeineromein Member Posts: 589
    Sure dude... Take you time m8!
    Oooh, and while you're at it, don't forget the AM, PM time thingy!
    "Real programmers don't comment their code.
    If it was hard to write, it should be hard to understand."
    I won't. Thx!
    Kind regards,
    Jan Hoek
    Product Developer
    Navision Binary Object File Viewer v0.1.2.14
    Jan,
    Wouldn't it be nice to be able to access the view option directly using a (not yet present) toolbar?
    Actually, I have tried that. It looked a bit silly, because the toolbar would have only two buttons. Besides, if you are using the mouse to sort the data anyway, you may as well click the column headers...
    Still, I will keep your suggestion in mind. Thx, mate!
    Kind regards,
    Jan Hoek
    Product Developer
    rejectorrejector Member Posts: 4
    does not display symbols in Russian language :(
    Navision Binary Object File Viewer v1.0.0.20
    Good point! I'll do my best fix that in the next version. Could you send me an example of a Russian .fob-file, and a screenshot of what these names should look like?
    Kind regards,
    Jan Hoek
    Product Developer
    ok, check mail zen.and.the.art.of.cside.development@inter.nl.net
    ps. by the way, at 'Navision Object Text Explorer' such problems
    Navision Binary Object File Viewer v1.0.1.23
    not even it is started: "error 1 in module 47"
    Did you place the cfront.dll in the same folder as the executable, and does you license give you access to C/Front?
    Kind regards,
    Jan Hoek
    Product Developer
    sure, cfront.dll nbofv.exe and *.fob files are in one directory.
    is license should be in the same directory?
    Yes, certainly. To be absolutely safe, copy fin.etx, fin.stx, slave.exe, dbm.dll, nc_tcp.dll, nc_netb.dll, and fin.flf from a 3.70 installation (since cfront.dll version 3.70 is included) to the folder in which nbofv.exe resides.
    Kind regards,
    Jan Hoek
    Product Developer
    Navision Binary Object File Viewer v1.0.1.27
    Simple and straight-forward, and not nearly as advanced as Michael Weigand's fob-viewer, this little application allows you to view .fob and .fbk files. Either pass a file name as a command line parameter, associate this viewer with .fob and .fbk files, select File|Open from the menu or drag & drop a file from Explorer.
    Features:
    - C/SIDE 4.0 object type-compatible;
    - Sorting;
    - Hiding system objects;
    - Exporting a list of objects as a text file;
    - Viewing license permissions per object.
    IMPORTANT: You need to install C/FRONT (Navision SDK) and copy the CFRONT.DLL file into the same directory as nbofv.exe.
    Note: Includes sources
    It seems that using multiple characters sets is a bit more difficult that I initially thought, so don't hold your breath. :wink:
    Kind regards,
    Jan Hoek
    Product Developer
