How use 5.0 Word/Excel export functionality in 4.0 database
edited 2009-02-17 in NAV Tips & Tricks
First. You have to get your license updated.
Export all the tables from 4.0. Uninstall 4.0. Install 5.0. Upgrade the db.
Import all the tables.
Open 5.0 Cronus. Export 690-694 Forms, and CU 403. Import them to the upgraded db.
In 5.0 Cronus. Design CU 1. Goto Function. Copy and paste the following function to Upgraded db.
LaunchApp
SelectStyleSheet
ManageStyleSheets
Compile and save CU 1.
Copy and past all the records from table following tables
2000000065 Send-To Program
2000000066 Style Sheet
That's it. Close the Upgraded database. and reopen it and now you can use the three new buttons.
