Google Maps - Show in Map / Show Route
ATAT Member Posts: 20
edited 2008-12-18 in NAV Tips & Tricks
I figured out how to show customers adresses in google maps without typing the adress manually in the browser. Just add a button with this code in the on push trigger to the customer card:
HYPERLINK('http://www.google.de/maps?f=q&hl=en&q=' +Address+' '+"Post Code"+' '+City);
For the route to the customer use this:
HYPERLINK('http://www.google.de/maps?f=d&hl=en&saddr=[from street]+[from post code]+[from city]&daddr='
In this example i coded the [from] adress in the button what is not the finest art. The option hl=en ist the langage of the user.
It is not a big thing, but sometimes a big help.
    krikikriki Member, Moderator Posts: 9,090
    [Topic moved from Navision e-Commerce forum to Navision Tips & Tricks forum]
    RogerSheetsRogerSheets Member Posts: 15
    Just a quick question on this ...
    So i add a Commandbutton to the form right?
    the only "push" option i see is PushAction with the choices of "Ok, Cancel, LookupOk, LookupCancel, Yes, No, Close, Stop, Formhelp, RunObject, RunSystem, Lookup Table"
    where do i add that code you referred to?
    click on the button and then hit F9. This will open the onpush trigger. If your license does not allow development, you won't be able to do it .
    wierd ... we have a developer license (at least i thought we did). I can design reports and use code in them, but not on the form. I'll have to check with our other developer to double check.
    thanks for the help!
    There are different granuales for forms and tables, and for reports that you can do development on.
    kinekine Member Posts: 12,562
    It means that you have just report designer. It is the base level of developer license. You need Application builder granule to be able to edit C/AL on forms, tables and codeunits.
    postacipostaci Member Posts: 116
    HI,
    I am trying to do this.
    I created another 3 fields in Contacts.
    1. Routeadres text 30
    2. Routepostcode code 20
    3. Routestad text 30
    Everyone can fill this in. This must be the homeadres.
    So it must be like ?:
    HYPERLINK('http://www.google.de/maps?f=d&hl=en&saddr=[routeadres]+[routepostcode]+[routestad]&daddr='
    But this doesn't work. second half works but FROM adress doesn't work.
    How Can I fix this ??
    :-k
    what about using " " around the string, because the string includes spaces? Or instead spaces you can use "%20"
    jmjm Member Posts: 156
    have a look at this code example:
    ContactStart.GET('KT000145');
    ContactEnd.GET('KT000003');
    HYPERLINK(
      'http://www.google.de/maps?f=d&hl=en&saddr='+
      ContactStart.Address+','+
      ContactStart."Post Code"+','+
      ContactStart.City+
      '&daddr='+
      ContactEnd.Address+','+
      ContactEnd."Post Code"+','+
      ContactEnd.City);
    And just to have al little fun with google maps try this:[code]
    http://www.google.de/maps?f=d&hl=en&saddr=München&daddr=New%20York
    Especially No. 38 in the list on the left side is verry interesting.
    br
    Josef Metz
    I already solved it. \:D/
    HYPERLINK('http://www.google.nl/maps?f=d&hl=en&saddr='+Routeadres+' '+Routepostcode+' '+Routestad+'&daddr='
    I just forget some quotes. That's all !!
    ooh yeahhhhhh ! =D>
    einsTeIn.NETeinsTeIn.NET Member Posts: 1,050
    Here you can figure out which parameters are possible and what is their meaning.
    "Money is likewise the greatest chance and the greatest scourge of mankind."
