Page N of M (Navision)
edited 2007-05-09 in Download section
This is simple process to display the page n of m in the report using the single data item.
http://www.mibuso.com/dlinfo.asp?FileID=752
    Nice try, but it only works for simple list reports. Customer would usually want it for documents f.e. invoices and for them this solution, I think, wouldn't work.
    Avdhesh_YadavAvdhesh_Yadav Member Posts: 5
    Hi, Miklos
    This may be the case.
    I will try for it.
    Now... knowing for certain the total no of pages in the middle of the pages creation is a bit of a paradox and probably one of them unsolvable problems. :)
    It's like knowing the future, if you knew something would happen you could prevent or change it, but then it wouldn't be future anymore...
    vyankuvyanku Member Posts: 791
    Yes I agree with u Miklos Hollender.
    For PO aand Invoice it is not usable
