I have a customer who is running Nav 4.00 SP1 SQL version around 40 users. They get the following Event Viewer messages on both of their Citrix boxes. I "THINK" they are getting it every time a client logs in. They are NOT using business notifications, however this seems to be tied to it (since it references it in the error message!) Can anyone shed some light???
Type: Error
Source: MessageBusAgent
Event ID: 0
Event Time: 3/10/2006 3:43:48 PM
User: n/a
Computer: EXPOMFXP1
Description:
Event message could not be found, but contained these strings: Connection property BN_PublishRetryTime_0 has not been set!
Please make sure that you have properly installed Business Notification Server.
Type: Error
Source: MetadataService
Event ID: 0
Event Time: 3/10/2006 3:43:36 PM
User: n/a
Computer: EXPOMFXP1
Description:
Event message could not be found, but contained these strings: Exception System.Net.Sockets.SocketException: Only one usage of each socket address (protocol/network address/port)
is normally permitted
at System.Runtime.Remoting.Channels.Tcp.TcpServerChannel.StartListening(Object data)
at System.Runtime.Remoting.Channels.Tcp.TcpServerChannel.SetupChannel()
at System.Runtime.Remoting.Channels.Tcp.TcpServerChannel..ctor(IDictionary properties, IServerChannelSinkProvider sinkProvider)
at System.Runtime.Remoting.Channels.Tcp.TcpChannel..ctor(IDictionary properties, IClientChannelSinkProvider clientSinkProvider, IServerChannelSinkProvider serverSinkProvider)
at Microsoft.BusinessSolutions.Integration.MetadataService.MetadataProvider.ctor() occured in .ctor
But in the environment we've setup we are now seeing this "Exception System.Net.Sockets.SocketException: Only one usage of each socket address (protocol/network address/port)" errors (as outlined above). Does anyone have any idea if BN & Citrix are incompatible or if there are just some configuration changes that need to be made?
Anyone else encountered this problem?
Epimatic Corp.
http://www.epimatic.com
