NAS Guru Wanted !!!
We have developed a codeunit which creates a text file. When we specify a file path to a shared VPN drive/folder, NAS (3.7a) falls over and does not log any messages into event viewer. NAS logs on as a domain administrator, so it is supposed to have full permissions. The path we specify contains an IP address (for example, \\123.456.7.89\shared_folder\text_file.txt).
If we run the same routine manually, everything is OK.
There are no issues when NAS writes file to a shared folder on a computer which normally is visible within network.
Any ideas what could be wrong? Thanks.
I've had it working with a mapped drive letter, so you may want to try that as well..
RIS Plus, LLC
MVP - Business Apps
The IP address is accessible from the NAS mashine.
When we run the same codeunit from NAS mashine, Navision sucessfuly creates a file, however we are not able to get the same results through NAS.
Mapped drive letter doesn't help either.
RIS Plus, LLC
MVP - Business Apps
Thanks for your readiness to help. We’ve spent many hours testing and we are coming to a conclusion that it might be a bug in NAS or some specific settings in VPN connection. Nevertheless, below is a simple test code that I’ve used for testing. NAS is not able to accomplish the 3rd part of the code. As soon as it comes to the 3rd MyFile.CREATE, NAS falls over.
// Write to a local hard drive
MyFile.CREATE('c:\NAStestLocal.txt');
MyFile.WRITE('Hello Mike!!!');
MyFile.CLOSE;
COMMIT;
// Write to a shared folder
MyFile.CREATE('\\accounts\webtest\NAStestSharedCompName.txt'); MyFile.WRITE('Hello Mike!!!');
MyFile.CLOSE;
COMMIT;
// Write to a shared VPN folder
MyFile.CREATE('\\192.168.1.13\d$\Navision\Import\NAStestSharedIP.txt');
MyFile.CLOSE;
COMMIT;
Best Regards,
Mindi
