I'm new to Navision development (3 weeks), is there a way to limit a user to at most 2 logins to server? (Using NAV 3.7)
i.e. Is there a way to see if other sessions are open for the current user?
Because for some reason some users feel the need to open more than 2 sessions. ](*,)
Kind Regards,
Ewald Venter
If you are using sql db you can find code on mibuso for disconnecting them when they have been idle too long.
You can check active sessions using database->information->sessions->current sessions. There you can also kick them.
The code I got can help, but is there no way to query the Database sessions table with C/AL code?
What I plan to do is to edit CU 1. When the user logs on and CU 1 executes, check how many times the user is logged on, if more than 2, kill the session.
Ewald Venter
Here the code: This code will close the client.
viewtopic.php?f=5&t=31486
