Color Change For Credit Memo's
edited 2010-03-18 in Navision Attain
When I pay a Vendor I go to the Payment Journal,
Enter the vendor #, blah blah & hit apply entries.
In which all that vendors OPEN enties appear.
I hit f9 to select which Invoices & credits I want to Pay & Use.
Some Vendors Have A ton of Entries. How can I make the Apply Vendor Enties Form show the credits in red?
01/01/01 - Invoice - 200
01/02/01 - Invoice - 201
01/03/01 - Invoice - 202
01/01/02 - Credit - 100
01/04/01 - Payment - 150
  • SavatageSavatage Member Posts: 7,142
    OK if I put it on
    OnFormat(VAR Text : Text[1024];)
    CASE "Document Type" OF
      "Document Type"::"Credit Memo" :
      CurrForm.Amount.UPDATEFORECOLOR(255);
      "Document Type"::Payment :
      CurrForm.Amount.UPDATEFORECOLOR(32768);
    ELSE
      CurrForm.Amount.UPDATEFORECOLOR(0);
    But How Can I Get The Whole Line To Be colored Without having to put this code on every field?
    Code Above Makes
    Credit=Red
    Payment=Green
  • Luc_VanDyckLuc_VanDyck Member, Moderator, Administrator Posts: 3,633
    Savatage wrote:
    [...] But How Can I Get The Whole Line To Be colored Without having to put this code on every field? [...]
    You can't. You have to duplicate this code on every column of the form.
  • Timo_LässerTimo_Lässer Member Posts: 481
    There is no chance. You have to write code in all OnFormat-Triggers of all fields which you want it.
    You can make it easier if you put your code in a function and only calls the function in the OnFormat-Trigger. This function then returns the color value.
    OnFormat(VAR Text : Text[1024]):
    CurrForm.YourControlName.UPDATEFORECOLOR(SetForeColor);
    SetForeColor() : Integer
      "Document Type"::"Credit Memo" : EXIT(255);
      "Document Type"::Payment : EXIT(32768);
      ELSE
        EXIT(0);
    Timo Lässer
    That's what I was Afraid of. Oh Well.
    out of all the changes I have made in Navision - this one has gotten one of the best responses.
    I've added it to several forms and even did the little
    if unit price = 0 change to red on sales orders thing.
    I guess when staring at a screen for 8 hrs a day - little changes like this really make the users happy.
  • FrabsFrabs Member Posts: 12
    hi,
    sorry for reactivate this :roll:
    How would the code look like if I would like to have unit price = 0 in the sales line ?
  • DenSterDenSter Member Posts: 8,304
    IF "Unit Price" = 0 THEN EXIT(ColorThatYouWant)
    Now we're allowed to add images :mrgreen:
    Endless beauty Harry, endless beauty... :mrgreen:
    Unfortunately Endless Beauty is out of business :lol:
  • AlexWileyAlexWiley Member Posts: 230
    ELSE
    Debugger is pointing at ELSE... I was just trying to use this as a starting point to play around with this and I immediately got nailed with this error I don't understand.
    I put this in the OnFormat(VAR Text : Text[1024];) of Document Type of Customer Ledger Entries, not Amount.
    ELSE
    That code is only good for the AMOUNT column. You probbay have it on another column that isn't Amount and you can't change the color of one field from another - hence the error...
    You have to change your code slightly for each column you want to change
    for example for the "Document No" column you would put this:
      CurrForm."Document No.".UPDATEFORECOLOR(255);
      CurrForm."Document No.".UPDATEFORECOLOR(16711680);
    ELSE
      CurrForm."Document No.".UPDATEFORECOLOR(0);
    For Posting Date this:
      CurrForm."Posting Date".UPDATEFORECOLOR(255);
      CurrForm."Posting Date".UPDATEFORECOLOR(16711680);
    ELSE
      CurrForm."Posting Date".UPDATEFORECOLOR(0);
    etc etc
    Yar, I can't believe I missed that, I got focused on 'CASE "Document No." OF and thought that was the call, I didn't even pay attention to the CurrForm call. Thank you Savatage, works perfectly now!
  • grofsgrofs Member Posts: 53
    Hy All,
    I read this topic, but I couldn't do line color change. :(
    I understand the code, but in case sales line color, where have to write the code?
    I couldnt find it! :(
    thx
    It's pretty clear if you back over the posts that the ON FORMAT trigger of the FORM is where the code goes.
    You have to put the code on every field you want to change - it will not do the whole line in one shot (I Know ](*,) )
    the only thing you have to change in the code as you go field by field isto change this part.
    CurrForm.Amount.UPDATEFORECOLOR(255); <<-- Use this on the Amount Field
    CurrForm."Posting Date".UPDATEFORECOLOR(255); <<--You would alterthe code to this if you are putting on the posting date field
    CurrForm."Document Type".UPDATEFORECOLOR(255); <<--You would alterthe code to this if you are putting on the document type field
    CurrForm."ETC, etc etc etc".UPDATEFORECOLOR(255);
