Navigation Pane menu item change
zamkinoszamkinos Member Posts: 4
hi, is there any way to change left pane menu items on database?
when i change a menu item's name with navigation pane designer, all users see this change.
So i think it's keeping in some table, not local file.
But which table and how can i update this table?
Navision 5.0 Sp1 with Sql Server 2008.
regards.
  • neilgfneilgf Member Posts: 148
    Are you using language packs at all? Which languages are installed? If more than 1 make sure you have made the same caption change to the menusuite for all language packs.
    Neil
