[NAV2015] Detect for what a report is created for
jonashedbergjonashedberg Member Posts: 7
edited 2015-05-06 in NAV Three Tier
Does anyone know if there is a way in a report detect what the report is created for?
Like if you want diffrent behavior if the result is an PDF, XML och on paper.
Jonas Hedberg
<a href="www.affarssystem.se">Senior Software Engineer, Update Affärssystem AB, Göteborg, Sweden</a>
    KishormKishorm Member Posts: 921
    You can use RenderFormat when designing the report Layout (I.e. not in C/AL code). There is a Microsoft "how do I" video on how to use this - just do a quick search
