How to scan concatenated fields barcode using PDA scanner
ChowdaryChowdary Member Posts: 148
Scanning bar-coded '*'+FORMAT("Prod. Order No.")+'*' is good.
But I have a requirement to scan
'*'+FORMAT("Prod. Order No.")+'\'+FORMAT("Line No.")+'*'
is this possible. If yes, please help me with suggession
Thank you
Pleasure in the job puts perfection in the work
    Hi Chowdari
    particulars really depend on how your scanner is "connected" to the NAV application. But in general, you receive the string from the scanner, split it using C/AL code and validate the NAV fields with the resulting data.
