Problem Creating PDF files in NAV
uri84uri84 Member Posts: 30
Hi all,
i have a report to create PDF files automatically, the reports works fine, but i don't know why every PDF is created, the pdf program opens the file...
I have a Runmodal like this:
Report.Runmodal(ReportSelection."Report ID",FALSE,FALSE,recSalesCrMemo);
This report is used by terminal server, and gets the configuration of the printer PDF terminal server , and the program used is: PDFill PDF&Image Writer
anyone knows if the problem is with configuration of the printer?
Thanks to all :)
  • uri84uri84 Member Posts: 30
    uri84 wrote:
    Hi all,
    Thanks to all :)
    I solve this problem... if anybody have this problema anytime, say that pdfill have an option called... show file after printing..... so you have to quit this mark.
    Thanks :P!
