Extended text to Comments in "sales header" on reports
kenneth73kenneth73 Member Posts: 59
edited 2015-02-01 in NAV Three Tier
I'm looking for some code or hints to, how to get "Extended text"-lines, and in the report CA/L insert these lines into the salesheader Comment Lines.
After the last Comment Lines if there is any.
Is this possible, and can someone provide me with some code examples
Regards Kenneth .. :)
    Are you saying you want to create a report that copies extended text info from sales lines into the sales header comments for a particular order?
    Or are you saying you want extended text info from sales lines to appear in the header section of a report?
    The Devils in the details.
