Sales ordre : departement code
kenneth73kenneth73 Member Posts: 59
edited 2014-12-21 in NAV Three Tier
I have made a copy of the Cronus Company.
The field in sales order : "departement code" is missing.
Could it have something to do with license ?
(I started with a standard license, and Then upgraded to advanced, and still on departement field)
I Think there is some setup I need to do ?.
Kenneth Jessen
    skullaskulla Member Posts: 140
    I don't think there is a field called Department Code, those are the captions for dimensions. The actual field is called "Shortcut Dimension 1 Code", you can setup the dimensions in Departments - Financial Management - Setup -> General Ledger Setup. (Use Change Global Dimensions from actions) If you setup global dimension 1 code as DEPARTMENT then the field will show as department code.
    Of course, I Can se it now... :)
