MBS Nav 2013 R2 Debugging
ArhontisArhontis Member Posts: 667
edited 2014-09-19 in NAV Three Tier
I have installed the Nav 2013 and when I choose "Run" on an object in the Dev Environment it opens the client ans how me the object.
If I press Run again it opens a second windows client to open the new object.
This makes it a bit difficult to debug, cause it opens a new session of the client each time I run an object in the dev env.
On the computer of a colleque of mine it works fine, it uses the same windows client to open the new object.
Any ideas on overcoming this malfunction?
Thank you in advance...
Best Answer
  • ArhontisArhontis Member Posts: 667
    Answer ✓
    Thanks for the effort on replying Tony, I should have searched about it much more before placing a post.
    The solution was found here (problem when having both 2013 and 2013 R2 versions installed):
    NAV2013 R2 - Run on Objects starts a new session
    http://www.mibuso.com/forum/viewtopic.php?f=32&t=61019
    Run CU or any object gives new session always
    http://www.mibuso.com/forum/viewtopic.php?f=32&t=61339
    Installing Microsoft Dynamics NAV 2013 R2 side-by-side with Microsoft Dynamics NAV 2013
    (http://blogs.msdn.com/b/nav/archive/201 ... -2013.aspx)
    And it was solved by running the powershell script that is stated at the above link. I copy/paste the powershell code here also for future use:
    #NAV 2013 and NAV 2013 R2 side-by-side install registry correction
    #---------Installation steps----------------
    # 1. Install NAv 2013, Install NAV 2013 R2 – this is not required if it is already done
    #     if there is installed NAV 2013 R2 only then this script just fix registry for 71
    # 2. Apply latest hotfixes (NAV 2013 R2 required later KB 2907588 build more 35850)
    # 3.run powershell as administor and execute "set-executionpolicy unrestricted"
    # 4. run this script
    if ( [System.IntPtr]::Size -eq 4 )
         "32-bits"
         try
            $nav70 = Get-ItemProperty -path "HKLM:\SOFTWARE\Microsoft\Microsoft Dynamics NAV\70\RoleTailored Client" -ErrorAction SilentlyContinue
    		$nav70exist = ($nav70.Path.Length -gt 0)
            $nav71 = Get-ItemProperty -path "HKLM:\SOFTWARE\Microsoft\Microsoft Dynamics NAV\71\RoleTailored Client" -ErrorAction SilentlyContinue
    		$nav71exist = ($nav71.Path.Length -gt 0)
            if ( $nav71exist)
               New-PSDrive -Name HKCR -PSProvider Registry -Root HKEY_CLASSES_ROOT
               #Remove
               Remove-Item -Path "HKCR:\TypeLib\{5020AC1E-A4F0-402B-A920-3FED4E3B05CC}" -Recurse -ErrorAction SilentlyContinue
               Remove-Item -Path "HKCR:\Wow6432Node\TypeLib\{5020AC1E-A4F0-402B-A920-3FED4E3B05CC}" -Recurse -ErrorAction SilentlyContinue
               Remove-Item -Path "HKCR:\Interface\{14519985-4959-4F7C-AC30-CBBCD9DFBC08}" -Recurse -ErrorAction SilentlyContinue
               Remove-Item -Path "HKCR:\Wow6432Node\Interface\{14519985-4959-4F7C-AC30-CBBCD9DFBC08}" -Recurse -ErrorAction SilentlyContinue
               remove-Item -Path "HKCR:\Interface\{59521B62-D441-47E6-8224-A07203686BA2}" -Recurse -ErrorAction SilentlyContinue
               Remove-Item -Path "HKCR:\Wow6432Node\Interface\{59521B62-D441-47E6-8224-A07203686BA2}" -Recurse -ErrorAction SilentlyContinue
               #Create again
               $net = Get-ChildItem C:\Windows\Microsoft.NET\ regasm.exe -Recurse | Select-Object -ExpandProperty FullName | Where-Object { $_ -like "*v4*"}
               If ($net -is [Array])
                    if ($nav70exist)
    				    { $exe70 = $net[0]+ ' /register ' + '"' + $nav70.Path +'Microsoft.Dynamics.Nav.Client.WinForms.dll" /tlb' }
                    $exe71 = $net[0]+ ' /register ' + '"' + $nav71.Path +'Microsoft.Dynamics.Nav.Client.WinForms.dll" /tlb'
               else
                    if ($nav70exist)
    				   { $exe70 = $net+ ' /register ' + '"' + $nav70.Path +'Microsoft.Dynamics.Nav.Client.WinForms.dll" /tlb' }
                    $exe71 = $net+ ' /register ' + '"' + $nav71.Path +'Microsoft.Dynamics.Nav.Client.WinForms.dll" /tlb'
               if ($nav70exist)
    		      { Invoke-Expression $exe70 }
               Invoke-Expression $exe71
             else
               Write-warning "Didn't find 2013 R2 in registry for 32-bit systems - NAV might be installed incorrectly" "Please reinstall products"
            catch
              Write-Warning "Had error in checking registry in 32 bits loop NAV might be installed incorrectly"
       elseif ( ([System.IntPtr]::Size -eq 8) )
        "64-bits"
         try
            $nav70 = Get-ItemProperty -path "HKLM:\SOFTWARE\Wow6432Node\Microsoft\Microsoft Dynamics NAV\70\RoleTailored Client" -ErrorAction SilentlyContinue
            $nav71 = Get-ItemProperty -path "HKLM:\SOFTWARE\Wow6432Node\Microsoft\Microsoft Dynamics NAV\71\RoleTailored Client" -ErrorAction SilentlyContinue
            if ($nav71exist)
               # Processing registry correction on 64-bits
               #Remove
                     if ($nav70exist)
               else
                    if ($nav70exist)
               if ($nav70exist)
             else
               Write-Warning "Didn't find 2013 R2 in registry for 64-bit systems - NAV might be installed incorrectly" "Please reinstall products"
            catch
              Write-Warning "Had error in checking registry in 64 bits loop NAV might be installed incorrectly"
  • TonyDuarteTonyDuarte Member Posts: 92
    What builds are you and your collegue using?
    And you do a simple trick, add that object temporary to the menu suite so that you can select it and still have the debug active.
    Answer ✓
         "32-bits"
         try
            if ( $nav71exist)
               #Remove
               #Create again
                    if ($nav70exist)
               else
                    if ($nav70exist)
               if ($nav70exist)
             else
            catch
        "64-bits"
         try
            if ($nav71exist)
               #Remove
                     if ($nav70exist)
               else
                    if ($nav70exist)
               if ($nav70exist)
             else
            catch
