NAV 2013 R2 Unknown Hard error when run page
darmaadarmaa Member Posts: 65
edited 2014-08-24 in NAV Three Tier
I`ve working on local customized module. When I run page from drilldown field, there is strange error "Unknown hard error" as shown attach file. I`m using build 7.1.36703.0.
I tried to debug it but it didnt found on debugger. and also didnt found any bug from NAV source. Please let me know any solution
  • rnshhrnshh Member Posts: 22
    That doesn't look like a normal NAV type error. Try exporting the object into text format and look for that error message.
    Tim Lecander
    ArcherPoint
  • navuser1navuser1 Member Posts: 1,329
    Revert back after doing the following things.
    1. Check the page thoroughly you want to open from the drilldown option.
    2. Remove the property value (if any) from the table/page and check.
    3. Remove the code under the trigger and kept the property value (if any) as is and check.
    Now or Never
