Error During Adjust Item Cost.
postsauravpostsaurav Member Posts: 708
edited 2014-08-04 in NAV Three Tier
Hi all,
All the Objects are standard in the database. This is W1 Database.
While running the Adjust Item Cost Entries, i am getting below error in NAV 2013 W1.
I know its exceeding the limit of Data type Length.
What can be the possible cause of the issue?
Thanks in advance.
Thanks & Regards,
Saurav Dhyani
Do you Know this About NAV?
Follow - Blog | Facebook Page | Google + Page
  • jglathejglathe Member Posts: 639
    sounds like a near-division by zero. Where does the debugger stop?
    with best regards
    Jens
  • postsauravpostsaurav Member Posts: 708
    Hey Jens,
    The Debugger Stops at Function SumCostsTillValuationDate in Table 5802.
    At the point -
    "Cost Amount (Actual) (ACY)" :=
        "Cost Amount (Actual) (ACY)" * QtyFactor + PrevValueEntrySum."Cost Amount (Actual) (ACY)";
    Let me know if you require any further information.
    Thanks & Regards,
    Saurav Dhyani
  • TonyDuarteTonyDuarte Member Posts: 92
    Did you check the values that are used in the calculation?
    These 3: QtyFactor and "Cost Amount (Actual) (ACY)" and PrevValueEntrySum."Cost Amount (Actual) (ACY)"
    I checked the start of the function, and I could say it could either be a problem with the QtyFactor calculation or something several SetRange's used before.
    But I have to ask what build are you using? It could be a problem already solved...
