Set XMLPort to all fields in a table automatic
NaCoderNaCoder Member Posts: 26
edited 2014-07-22 in NAV Three Tier
is there a way with XML-Ports to set all fields in a table automatic.
We have some hundrets ob tables with fields, so it is not usefull to set every field.
The next is if there are changes of fields. So it is good when there a way to set the table only and not the fields extra.
Or any solution with C/AL?
