Filters / Reports
TL02474TL02474 Member Posts: 9
edited 2005-04-28 in NAV Tips & Tricks
Hello
Reports:
A "P" on a Date filter will return the To..From of the accounting period dates. Does anyone have a Tip/Trick for getting the prior accounting period?
M,T,W,T,F will get you Monday - Fridays Date
W, will get you the work date
T, will get you todays date
Any others?
Navision Implementation Consultant
Manufacturing Certified
    TL02474 wrote:
    Hello
    p-1
    TL02474 wrote:
    Hello
    actually you can't have T = Tuesday, Thusday & Today
    & W = Wednesday & Work Date
    Mo,Tu,We,Th,Fr would work for the day's of the week.
    Not that I ever had a use for that :-k
    Thanks Luc Van Dyck, P-1 worked fine.
