It is currently Thu Aug 27, 2015 9:20 pm
 Post subject: Add Record Link via webservice?
PostPosted: Fri Apr 19, 2013 10:22 pm
Country: United States (us)
I'm trying to create a program to automatically add URL links to G/L and Vendor Journal entries. Since the program will be "outside" of Navision, I want to do this via a webservice. So far, I haven't found a Page or CodeUnit that provides functionality to create a Record Link.
Is there any way I can get at the Record Links via a webservice?
Just to be clear, the links I'm trying to add should end up in table 2000000068, "Record Link". This for NAV 2009.
 Profile E-mail
 Post subject: Re: Add Record Link via webservice?
PostPosted: Mon Apr 29, 2013 3:24 am
Country: Australia (au)
You could create a new codeunit and add it to the web service table.
Then, you just need to create a function in the codeunit to add the link to your record by using the addlink function.
record.addlink(url,description)
Cheers
 Profile E-mail
PostPosted: Tue Feb 18, 2014 1:19 am
Country: Portugal (pt)
there is not possible to add it just on c#?
can you send a sample code to have on codeunit..
i need to add a file to attach on Purchase Header on record link..
do you know a easy way?
 Profile E-mail
PostPosted: Wed Feb 19, 2014 12:11 am
Just create a new codeunit and add it to the web service table.
Then, create a new function in the codeunit called something like "AddPurchHeaderLink" with the Purchase Number, the description of the link and the url of the link as parameters.
Then, you only need to do something like that
Code: Select all
PurchHeader.GET(YourPurchaseNumber);
PurcHeader.ADDLINK(URL,Description);
Hope it makes sense
 Profile E-mail
Users browsing this forum: Google [Bot] and 6 guests
