It is currently Sun Mar 29, 2015 2:39 pm
Post new topic Reply to topic  [ 11 posts ]
 Post subject: [Solved] The type NavBoolean is unknown
PostPosted: Fri Apr 19, 2013 8:59 pm
Country: Canada (ca)
I am getting the following error when trying to rename the record in the table. Any ideas? There is no any code OnRename trigger. NAV2013.
 Profile
 Post subject: Re: The type NavBoolean is unknown
PostPosted: Sat Apr 20, 2013 1:07 am
MVP Microsoft Dynamics NAV
Country: United States (us)
Try using the debugger. It will help you pinpoint the problem.
_________________
Harry Ruiz
http://www.BiloBeauty.com
http://www.autismspeaks.org
 Profile E-mail WWW
PostPosted: Sat Apr 20, 2013 5:57 pm
Debugger doesn't help. There is no any code neither at OnRename trigger nor Code - OnValidate. Also, there is no TableRelation on this field. PrimaryKey contains of one field (Code) only.
 Profile
PostPosted: Sun Apr 21, 2013 2:48 pm
So are you saying..you tried the debugger and nothing happened or you didn't try at all?
http://msdn.microsoft.com/en-us/library/dd354968.aspx
_________________
Harry Ruiz
 Profile E-mail WWW
PostPosted: Sun Apr 21, 2013 11:36 pm
Yes, I know what debugger is, and I tried to use it in this case. Nothing happened.
 Profile
PostPosted: Mon Apr 22, 2013 6:51 am
Country: India (in)
Hi Alex9,
The code field is primary key field and in other table, Fields are connected with this field using Table Relation.
The problem might be that when you try to rename field "Code" shown in screenshot, it also goes to update other field value whose are connected with "Code" field in Table relation Property. You should check for all fields and their data type which are connected with "Code" field and their data type.
I think data type of any one field does not match with the data type of "Code" field .
If suggestion has solved your problem then please do not forget to mark it as solved.
 Profile E-mail
 Post subject: SOLVED: The type NavBoolean is unknown
PostPosted: Mon Apr 22, 2013 3:39 pm
dipakpatel2505 wrote:
Hi Alex9,
Hi dipakpatel2505,
You are absolutely right! I searched for table relations throughout the whole database and found boolean field in another table with relation to this Code field. Thanks a lot for your help! :)
 Profile
PostPosted: Thu Mar 26, 2015 6:23 pm
I am getting this same error on trying to rename a record in a new custom table with the primary key a Code 10 field. There are 4 tables with fields relating to this table but all are defined correctly as Code 10. How did you find a field of type Boolean with a table relation to this table? Or what else could be causing this error?
 Profile E-mail
 Profile E-mail
PostPosted: Thu Mar 26, 2015 6:41 pm
Country: Germany (de)
You may query the table Field filtering by RelationTableNo = [YourTable] and RelationFieldNo = [YourField].
_________________
* Daniele Rebussi * | * Rebu NAV Diary *
 Profile E-mail WWW
PostPosted: Thu Mar 26, 2015 6:44 pm
I finally found it by exporting all the recently modified tables as txt and searched for the table name
 Profile E-mail
Users browsing this forum: Google [Bot] and 6 guests
