NAV 2013 ADOConnection
mathieukmathieuk Member Posts: 15
edited 2013-04-02 in NAV Three Tier
Hi Guys,
Hopefully someone can help me with this.
I'm doing a NAV migration from 2009 to 2013 and there is something I can't make working.
I've got a function that's executing a stored procedure in another SQL database using the following automations:
'Microsoft ActiveX Data Objects 2.8 Library'.Connection
'Microsoft ActiveX Data Objects 2.8 Library'.Command
'Microsoft ActiveX Data Objects 2.8 Library'.Parameter
Then, I've got this code:
IF ISCLEAR(ADOConnection) THEN
CREATE(ADOConnection);
When I try to save the function, it gives me this error:
"You cannot create Automation object "ADOConnection" on NAV server. You must create it on the client computer."
Can't we use automations with NAV 2013?
If not, any other way I can execute a stored procedure from NAV 2013? using DotNet variables?
Cheers
    mohana_cse06mohana_cse06 Member Posts: 5,503
    Yes, use
    CREATE(ADOConnection,FALSE,TRUE);
    If you want to use DotNet variable then try below blog
    http://mibuso.com/blogs/ara3n/2011/01/10/using-ado-on-rtc-in-nav/
    You can also look at the upgrade toolkit that uses dotnet interop for this.
    Thanks guys for your answers.
    I'm going to use the DotNet variables as mohana_cse06 suggested.
    However, do you know how to add parameters to the SQLCommand?
    Hi guys,
    I've finally found the solution.
    Here is the code, it might help someone else.
    L_SQLConnection := L_SQLConnection.SqlConnection(ConnectionString);
    L_SQLConnection.Open;
    L_SQLCommand := L_SQLCommand.SqlCommand('[dbo].[DeleteUser]',L_SQLConnection);
    L_SQLCommand.CommandType := 4; // for a stored proc
    L_SQLCommand.Parameters.Add('@ApplicationName','test');
    L_SQLCommand.Parameters.Add('@UserName',L_Login."User Id");
    L_SQLCommand.ExecuteReader();
    L_SQLConnection.Close;
    CLEAR(L_SQLCommand);
    CLEAR(L_SQLConnection);
    Variables
    Name DataType Subtype Length
    L_SQLConnection DotNet System.Data.SqlClient.SqlConnection.'System.Data, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'
    L_SQLCommand DotNet System.Data.SqlClient.SqlCommand.'System.Data, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'
    Cheers
