NAV 2013 SQL Query Codeunit
edited 2012-11-25 in Download section
For those times when the new Query objects (as good as they are) just aren't enough and you're desperate for direct SQL access as a last resort.
Simple codeunit allows you to execute an SQL query to populate any NAV (temporary) table using one call. Test page is included to demonstrate functionality with a simple query. 2013 version does not use COM (all code runs on NST), but zip file also includes COM version for pre-R2 NAV.
Note that users will be required to have select access to the tables in SQL Server to run this code.
http://www.mibuso.com/dlinfo.asp?FileID=1510
