It is currently Tue May 21, 2013 12:39 am
 Post subject: showing RTC Report and NOT Classi Report
PostPosted: Tue Aug 28, 2012 2:45 pm
Country: Netherlands (nl)
I developed as a start fo converting 3.7 to NAV R2 a Customised Order Confirmation Report.
I I try to see it via
dynamicsnav:////runreport?report=[Number]
wher [Number] is my report number then the Classic Request Form and Report is shown and not he RTC one.
How can I test a RTC Report without linking it first to a page or action etc. ?
:roll:
 Profile
 Post subject: Re: showing RTC Report and NOT Classi Report
PostPosted: Tue Aug 28, 2012 2:54 pm
MVP Microsoft Dynamics NAV
Country: India (in)
Did you create rdlc layout for report?
If not, it will open classic report only from RTC..
Create rdlc layout and transform the request form to request page using trnasformation tool and try..
_________________
-Mohana
http://mibuso.com/blogs/mohana
http://mohana-dynamicsnav.blogspot.in/
 Profile
PostPosted: Tue Aug 28, 2012 3:06 pm
Yes I opened the existing Report, used the Function Suggest Layout, Modified the layout, saved the Report.
Do I need to change the Option Page onlz if I have Options?
William
 Profile
PostPosted: Tue Aug 28, 2012 10:51 pm
NAV TechDays 2013 attendee
Country: Denmark (dk)
In NAV 2009 the program will check if RDLC layout exist on Report when running the report.
If no RDLC layout Classic report will be displayed.
If RDLC exist the Report will open in Report Viewer 2008.
Export you report to txt and verify that RDLC layout exist in the bottom of the report.
If it just says:
Code: Select all
  RDLDATA
Then you have no layout.
/Claus Lundstrøm
_________________
Claus Lundstrøm | Senior Product Manager | Abakion.com
I'm blogging here:http://mibuso.com/blogs/clausl and used to blog here: http://blogs.msdn.com/nav
 Profile
Users browsing this forum: No registered users and 13 guests
