vandang wrote:
Thanks Sog,
let me clarify each parameter you point out:
ip: 192.168.0.100
port: 2407
instance: ??? please tell where I can get this one
so the completed path in my NAV client now is 192.168.0.100:2407/????? and placed it on the Server Name field
I don't see why this is so much complicated.
if you have NAV native server properly installed, then it is a matter of opening CSIDE Client on the client machine (hope there is a network connectivity in place),
select File-->Database-->Open and in the open database windows:
enter NAV Server pc IP address in "server name", select the appropriate "Net Type" under Advance tab (most of the time, it will be TCP). If you have defined a username and password in the database, enter them also. Click OK to open the database in client.
