It is currently Sun May 19, 2013 7:30 pm
Post new topic Reply to topic  [ 6 posts ]
 Post subject: add total field to report id 109 customer summary ageing
PostPosted: Wed Aug 01, 2012 5:03 pm
Country: Saudi Arabia (sa)
in report id 109 customer summary aging simple in reports default in dynamic nav i found this code written in after get report trigger:
PrintCust := FALSE;
FOR i := 1 TO 5 DO BEGIN
DtldCustLedgEntry.SETCURRENTKEY("Customer No.","Initial Entry Due Date","Posting Date");
DtldCustLedgEntry.SETRANGE("Customer No.","No.");
DtldCustLedgEntry.SETRANGE("Posting Date",0D,StartDate);
DtldCustLedgEntry.SETRANGE("Initial Entry Due Date",PeriodStartDate[i],PeriodStartDate[i + 1] - 1);
DtldCustLedgEntry.CALCSUMS("Amount (LCY)");
CustBalanceDueLCY[i] := DtldCustLedgEntry."Amount (LCY)";
IF CustBalanceDueLCY[i] <> 0 THEN
PrintCust := TRUE;
IF NOT PrintCust THEN
CurrReport.SKIP;
that found before is 0-30,31-60,61-90
what i need is to total variable that consist of amount( debit -credit)
meaning how i write this by coding
total =amount for 0-30+amount for 31-61+amount for 61-91
thanks
 Profile E-mail
 Post subject: Re: add total field to report id 109 customer summary agein
PostPosted: Wed Aug 01, 2012 5:24 pm
Moderator
MVP Microsoft Dynamics NAV
NAV TechDays 2013 attendee
Country: Italy (it)
Code: Select all
TotalAmount := 0; //NEW LINE
PrintCust := FALSE;
  TotalAmount += TotalAmount + DtldCustLedgEntry."Amount (LCY)"; //NEW LINE
    PrintCust := TRUE;
  CurrReport.SKIP;
// "TotalAmount" contains the total amount
_________________
Use the SEARCH,Luke! || No PM,please use the forum. || May the <SOLVED>-attribute be in your title! || Read Forum Rules before making a posting
 Profile
PostPosted: Thu Aug 02, 2012 12:42 pm
OK thanks it run but i have another question if i want to calculate debit amount(debit amount(lcy)) from 1 to 5 and total as i make before what the modification that must make in code
meaning
total 0-30 31-60 61-91
debit-credit(already made) debit amount(lcy) debit amount(lcy) debit amount(lcy)
what is the modification i must make to make this formula
please help me.
thanks
 Profile E-mail
PostPosted: Thu Aug 02, 2012 1:38 pm
Moderator
Country: Italy (it)
Instead of using "Amount (LCY)", you can use "Debit Amount (LCY)" and "Credit Amount (LCY)" for debit and credit amounts.
_________________
 Profile
PostPosted: Thu Aug 02, 2012 2:16 pm
OK I make this code as following :
PrintCust := FALSE;
total:=0;
DtldCustLedgEntry.CALCSUMS("Debit Amount (LCY)");
CustBalanceDueLCY[i] :=DtldCustLedgEntry."Debit Amount (LCY)";
CustBalanceDueLCYAm[i] :=DtldCustLedgEntry."Amount (LCY)";
total:=total+DtldCustLedgEntry."Amount (LCY)";
PrintCust := TRUE;
Curr Report.SKIP;
but message error display there are too many dimension the variable defined with little dimension.
why this message display
what i need is display total(debit -credit to all package) and debit amount to every package as following 0-30,31-60,61-90.
thanks
 Profile E-mail
PostPosted: Thu Aug 02, 2012 4:35 pm
Moderator
Country: Italy (it)
You need to give dimensions to your new variable. Check the properties of the old variable to see what I mean.
BTW: you really should take some C/AL courses or have you assisted by a senior C/AL developer. This is very basic stuff!
_________________
 Profile
Users browsing this forum: Google [Bot] and 10 guests
