It is currently Sat May 18, 2013 10:13 pm
Post new topic Reply to topic  [ 2 posts ]
 Post subject: Remove Applied Entries in Application Worksheet
PostPosted: Sun Jul 29, 2012 12:20 pm
Country: Singapore (sg)
In Application worksheet. For any entries which has the applied entries we can click and view the applied entries and then we can remove manually applied entries one by one (as this automatically applied by the system)
Is there any batch job which can remove all the applied entries? And all the “Remaining Quantity” should equal as the “Quantity” and should be open..
Kindly post your suggestions
_________________
Samu Thangadurai
 Profile E-mail
 Post subject: Re: Remove Applied Entries in Application Worksheet
PostPosted: Sun Jul 29, 2012 1:21 pm
Country: India (in)
This is not in standard nav if you want to remove all application then you need to create a batch job playing around with how's application worksheet working for single application.
_________________
Vijay Gupta
Changing the code is last step. Try to change processes first...
 Profile E-mail
Users browsing this forum: No registered users and 11 guests
cron
