It is currently Thu May 23, 2013 8:44 am
 Post subject: [Solved] [NAV2013] Show as Chart does not display flowfield values?
PostPosted: Fri Jul 27, 2012 4:04 pm
Country: Belgium (be)
Hi experts,
It seems that the "Show as Chart" feature does not display flowfield values in NAV 2013.
For example if I try to display a chart with Amount by "Bill-to Name" on the Sales Order List:
While in 2009R2 it used to work:
Is this a known bug? Do you experience the same issue? Thanks for your feedback :)
 Profile E-mail
 Post subject: Re: [NAV2013] Show as Chart does not display flowfield value
PostPosted: Tue Jul 31, 2012 2:50 pm
Country: France (fr)
Hi Ben,
I think it's a bug. It will probably be corrected by the final version or a Beta fixed version.
Microsofties already have this fixed version.
Have a great day.
 Profile E-mail
PostPosted: Mon Aug 06, 2012 9:59 am
Microsoft employee
Country: Denmark (dk)
The bug has been fixed - unfortunately the fix did not make it into the BETA build. Builds after BETA will be able to use flow fields for charts.
/henrik
_________________
“This posting is provided "AS IS" with no warranties, and confers no rights.”
Henrik Metzger, Software Development Engineer, Dynamics NAV
MSFT
 Profile E-mail WWW
PostPosted: Fri Jan 04, 2013 3:31 pm
Indeed it seemed to be a bug and its now fixed in the release :)
Thanks for your help !
 Profile E-mail
Users browsing this forum: No registered users and 6 guests
