It is currently Sun May 19, 2013 8:19 pm
 Post subject: NAV 7 Web Client - error when trying to open web client
PostPosted: Thu Jul 05, 2012 2:59 pm
Country: Belgium (be)
Dear,
As in the following blog post : viewtopic.php?f=32&t=53505
I've troubles to connect to the web client when using windows authentication.
Here are the messages I get:
And after refresh:
Here is what appears in the Application event viewer:
Code: Select all
Type: System.UnauthorizedAccessException
Message: Access to the registry key 'Global' is denied.
StackTrace:
     at Microsoft.Win32.RegistryKey.Win32Error(Int32 errorCode, String str)
     at Microsoft.Win32.RegistryKey.InternalGetValue(String name, Object defaultValue, Boolean doNotExpand, Boolean checkSecurity)
     at Microsoft.Win32.RegistryKey.GetValue(String name)
     at System.Diagnostics.PerformanceMonitor.GetData(String item)
     at System.Diagnostics.PerformanceCounterLib.GetPerformanceData(String item)
     at System.Diagnostics.PerformanceCounterLib.get_CategoryTable()
     at System.Diagnostics.PerformanceCounterLib.CategoryExists(String machine, String category)
     at System.Diagnostics.PerformanceCounterCategory.Exists(String categoryName, String machineName)
     at System.Diagnostics.PerformanceCounterCategory.Exists(String categoryName)
     at Microsoft.Dynamics.Framework.UI.WebBase.Diagnostics.CounterExistsPerformanceCounterEnabledStrategy.get_IsEnabled()
     at Microsoft.Dynamics.Framework.UI.WebBase.Diagnostics.SystemPerformanceCounter.Increment()
     at Microsoft.Dynamics.Framework.UI.WebBase.ClientSessionManagerBase.OnClientSessionCreated(ClientSessionCore createdSession)
     at Microsoft.Dynamics.Framework.UI.ClientSessionManagerCore.CreateClientSession(String sessionId)
     at Microsoft.Dynamics.Framework.UI.ClientSessionManagerCore.EnsureSession(String sessionId)
     at Microsoft.Dynamics.Framework.UI.Web.ClientSessionManager.EnsureSession()
     at Microsoft.Dynamics.Framework.UI.Web.FormControl.OnInitCore(EventArgs e)
     at Microsoft.Dynamics.Framework.UI.Web.FormControl.<>c__DisplayClass3.<OnInit>b__2()
     at Microsoft.Dynamics.Framework.UI.Web.WebEventExecutor.<>c__DisplayClass3.<Execute>b__2()
     at Microsoft.Dynamics.Framework.UI.Web.WebEventExecutor.ExecuteCore[T](Func`1 webEvent, Func`1 condition)
Source: mscorlib
Code: Select all
Type: System.ArgumentNullException
Message:
  Value cannot be null.
  Parameter name: key
ParamName: key
StackTrace:
     at System.Collections.Generic.Dictionary`2.FindEntry(TKey key)
     at System.Collections.Generic.Dictionary`2.TryGetValue(TKey key, TValue& value)
     at Microsoft.Dynamics.Framework.UI.WebBase.WebSessionStateProvider.Unregister(ClientSessionBase clientSession)
     at Microsoft.Dynamics.Framework.UI.WebBase.ClientSessionManagerBase.OnClientSessionRemoved(ClientSessionCore removedSession)
     at Microsoft.Dynamics.Framework.UI.ClientSessionManagerCore.RemoveClientSession(ClientSessionCore clientSession)
     at Microsoft.Dynamics.Framework.UI.ClientSessionCore.Dispose(Boolean disposing)
     at Microsoft.Dynamics.Framework.UI.WebBase.ClientSessionBase.Close()
     at Microsoft.Dynamics.Framework.UI.Web.ClientSession.OnExitProcessing()
     at Microsoft.Dynamics.Framework.UI.WebBase.ClientSessionBase.ExitProcessingCore()
     at Microsoft.Dynamics.Framework.UI.WebBase.ClientSessionBase.ExitProcessing()
     at Microsoft.Dynamics.Framework.UI.Web.FormControl.UnloadCleanup()
     at Microsoft.Dynamics.Framework.UI.Web.FormControl.<OnUnload>b__17()
Source: mscorlib
I've tried the following:
Complete reinstall of IIS, NAV Web Client, whole NAV features.
Rebuild of Performance counters
Edit registry to allow access to performance counters
It sure has something to do with the fact that I use windows logins (permissions missing?)
Thanks for your help ;)
File comment: Then after refresh
File comment: First message I get
 Profile E-mail
 Post subject: Re: NAV 7 Web Client - error when trying to open web client
PostPosted: Thu Jul 05, 2012 3:35 pm
Just solved the error by adding the Guest group to the Performance Monitor User group.
Now it works like a charm! :)
Edit: now it's not working again :(
If I add a single windows login to the Perf Monitor Users group it works..
 Profile E-mail
PostPosted: Thu Jul 05, 2012 5:29 pm
Ok so to solve this issue I added "Domain Users" group to the "Perf Monitor Users" group.
I'll investigate with the people managing the domain if it could cause any security concerns but this is the only workable solution I found so far.
 Profile E-mail
PostPosted: Tue Oct 30, 2012 6:08 pm
Country: Italy (it)
Same error, but after an update of server (2008R2).
I resolve it adding Network service to Performance Monitor Users group.
 Profile
Users browsing this forum: No registered users and 8 guests
