It is currently Fri May 24, 2013 4:04 pm
Post new topic Reply to topic  [ 7 posts ]
 Post subject: Name of the caller object
PostPosted: Tue Jun 26, 2012 3:13 pm
Country: Canada (ca)
Hi all.
I have one small question:
Say Object "X" is calling object "Y".
How Object "Y" can tell what is the caller object?
Is there any method in C/Side to get the name / no. of the caller object
other than using Single Instance Code Unit - like using set and get funtions?
 Profile E-mail
 Post subject: Re: Name of the caller object
PostPosted: Wed Jun 27, 2012 7:52 am
MVP Microsoft Dynamics NAV
NAV TechDays 2013 attendee
Country: Czech Republic (cz)
No, there is no way for that. Why you need that? I do not know any business process which will need that.
_________________
 Profile E-mail WWW
PostPosted: Wed Jun 27, 2012 3:59 pm
Thanks for you reply
We need Item Tracking Lines (Form 6510) behave a little bit differently when called from Purchase Order (Form 50)
- like some fields would become disabled , some fields would be autofilled etc. based on which Form is calling it.
Thanks and regards
Fazle
 Profile E-mail
PostPosted: Wed Jun 27, 2012 4:28 pm
Site Supporter
Thanks and regards
Fazle
You may try adding a Global variable and setting its value before calling. and check for the flag in form opening.
there may be other better ways!
_________________
"A bove maiore discit arare minor"-"From the old ox, the young one learns to plow."
 Profile E-mail
PostPosted: Wed Jun 27, 2012 4:36 pm
The write two separate functions in the code unit and call a different function depending on your needs.
_________________
David Singleton
Dynamics NAV Freelancer
Dynamics Book
Go-Live International
 Profile E-mail WWW
PostPosted: Wed Jun 27, 2012 4:44 pm
You already have this in the form - variable CurrentSourceType is ID of table from where it was called (Sales Line, Purchase Line)… just look into existing code, there are conditions making the proces differend based on the calling source...
_________________
 Profile E-mail WWW
PostPosted: Fri Jun 29, 2012 3:28 pm
 Profile E-mail
Users browsing this forum: Google [Bot], Pinkycz and 18 guests
