It is currently Fri May 24, 2013 10:43 am
 Post subject: NAV FTP Client v1.1
PostPosted: Thu Jun 14, 2012 2:14 pm
Site Admin
Country: Belgium (be)
NAV FTP Client
Automation control for Dynamics NAV to Upload and Download files from FTP. Track progress within NAV with a dialog window.
Includes setup.exe for installation.
http://www.mibuso.com/dlinfo.asp?FileID=1449
 Profile
PostPosted: Sun Jun 17, 2012 11:42 am
Site Admin
NAV FTP Client v1.1
New: Set passive mode, Delete file on FTP and list FTP directoty.
Ver 1.1
New functions:
DeleteFileOnFTPServer()
ListFTPDirectory()
GetDirectoryList()
New Property
Passive
Sample code:
Code: Select all
MESSAGE(NAVFTP.DeleteFileOnFTPServer('home/database.fdb'));
NoOfLines := NAVFTP.ListFTPDirectory('home',FALSE);
IF NoOfLines > 0 THEN
  FOR i := 1 TO NoOfLines DO
    MESSAGE(NAVFTP.GetDirectoryList(i));
 Profile
 Post subject: Re: NAV FTP Client v1.1
PostPosted: Mon Nov 26, 2012 5:43 pm
I have been looking for an FTP solution without the use of the SHELL command in NAV.
As usual, Mibuso comes to the rescue :).
I have been playing around with your solution for a bit now, but the UploadFile function returns an error. The function GetDirectoryList works fine, so the FTP connection is definitly there.
Attached you'll find a screenshot of the error.
Raw translation of the error:
"Cannot convert an object of type System.ComponentModel.AsyncOperation to type UploadBitsState."
I am running this on Windows 7 - 64 bit, in NAV 2009 SP 1.
Kind regards
Marten
EDIT: The problem was a faulty 'FROM' parameter. Of course 'C:\test,txt' does not work. It had to be 'C:\test.txt'...
File comment: Error UploadFile function
 Profile E-mail
PostPosted: Thu Jan 03, 2013 6:19 pm
Country: Spain (es)
thanks you.
It run fine.
I need a RENAME function because when COPY the LS return it.
 Profile E-mail
Users browsing this forum: No registered users and 4 guests
