It is currently Thu Jan 29, 2015 7:21 pm
Post new topic Reply to topic  [ 22 posts ]  Go to page 1, 2  Next
 Post subject: You do not have the following permissions on CodeUnit Applic
PostPosted: Tue Jun 12, 2012 11:04 am
Country: Turkey (tr)
I installed nav 7 successfull. But I try to run "C:\Program Files (x86)\Microsoft Dynamics NAV\70\RoleTailored Client\Microsoft.Dynamics.Nav.Client.exe" i get a error. How can i solve this problem.
You do not have the following permissions on CodeUnit ApplicationManagement: Execute
_________________
Ibrahim COBANI | Dynamics-NAV Developer Team Manager
I m a Consult
E-Mail: ibrahim@imaconsult.com
 Profile E-mail
 Post subject: Re: You do not have the following permissions on CodeUnit Ap
PostPosted: Tue Jun 12, 2012 11:16 am
Country: Spain (es)
You probable do not have correctly defined permissions for your user inside the NAV.
 Profile E-mail
PostPosted: Tue Jun 12, 2012 11:23 am
I cant find user permision defined menu in NAV Development Environment.
_________________
I m a Consult
 Profile E-mail
PostPosted: Tue Jun 12, 2012 11:34 am
Country: Spain (es)
With NAV 2013 you have to enter into the RTC to setup the permissions. Have you configured any user before in RTC or this is your first try to enter?
 Profile E-mail
PostPosted: Tue Jun 12, 2012 11:41 am
Yes, I m trying first time and RTC give me this error.
OK
_________________
I m a Consult
 Profile E-mail
PostPosted: Tue Jun 12, 2012 3:56 pm
How can i add a user with super role from Microsoft Dynamics NAV 2013 PowerShell. I cannot enter RC.
_________________
I m a Consult
 Profile E-mail
PostPosted: Wed Jun 13, 2012 9:26 am
Microsoft employee
Country: Denmark (dk)
Have you installed the Microsoft Dynamics NAV 2013 on the same SQL server as a Microsoft Dynamics NAV 2009 R2 installation?
If that is the case then try to upload a Microsoft Dynamics NAV 2013 license to the local database and see if that helps. The licenses for Microsoft Dynamics NAV 2013 and Microsoft Dynamics NAV 2009 R2 are not completely identical and if you have a Microsoft Dynamics NAV 2009 R2 license in the master database it will be picked up by Microsoft Dynamics NAV 2013.
Alternatively you can try to install Microsoft Dynamics NAV 2013 on a separate server with no prior Microsoft Dynamics NAV installation.
Claus Jakobsen
Senior Software Developer
Dynamics NAV Server
Microsoft
This posting is provided "AS IS" with no warranties, and confers no rights.
_________________
Claus Jakobsen
Dynamics NAV Server
Microsoft
 Profile E-mail
PostPosted: Thu Jul 26, 2012 8:18 am
Country: Italy (it)
Hi icobani, did you find a solution for this issue?
_________________
~Rik~
It works as expected... More or Less...
 Profile E-mail
PostPosted: Fri Jul 27, 2012 2:39 pm
Country: Italy (it)
Hi we solved it accesing NAV through SysAdmin user.
He inserted "SUPER" permission for my user and then I was able to login.
_________________
~Rik~
 Profile E-mail
PostPosted: Tue Oct 23, 2012 7:35 am
I have the same issue and can not identify the reason. Searched mibuso and can find only this topic.
Here are some information about my case:
No prior NAV installations exist.
Database server and application are in the same server.
I do not have partner license for 2013 but have demo license and I think it should also work.
System does not create any log in events.
No user defined in the system. (so I'm not sure if this is the same with Troubles In Paradise's)
I can access developer environment but can not access to RTC.
_________________
Ufuk Asci
Pargesoft
 Profile
PostPosted: Tue Oct 23, 2012 7:38 am
MVP Microsoft Dynamics NAV
NAV TechDays 2014 attendee
Country: India (in)
Can you show us the exact error message?
_________________
-Mohana
http://mibuso.com/blogs/mohana
http://mohana-dynamicsnav.blogspot.in/
https://www.facebook.com/MohanaDynamicsNav
 Profile
PostPosted: Tue Oct 23, 2012 8:17 am
The message that displayed in the first post of this topic:
"You do not have the following permissions on CodeUnit ApplicationManagement: Execute"
_________________
Ufuk Asci
Pargesoft
 Profile
PostPosted: Tue Oct 23, 2012 8:21 am
Country: India (in)
Try Uploading NAV2013 license again and restart services..
_________________
-Mohana
 Profile
PostPosted: Tue Oct 23, 2012 8:26 am
I already uploaded demo license. (I do not have partner license for 2013)
Which services do you mean? I see MicrosoftDynamicsNavServer$DynamicsNAV70 and MicrosoftDynamicsNavVSS (don't think it's required) I alreday tried restarting the service but nothing had changed.
Thank you.
_________________
Ufuk Asci
Pargesoft
 Profile
PostPosted: Tue Oct 23, 2012 11:48 am
Done. I deleted the Access Control record from SQL and be able to access RTC.
_________________
Ufuk Asci
Pargesoft
 Profile
Users browsing this forum: No registered users and 8 guests
cron
