The 4.00 Fixed Files !
The release of 4.00 contained a bunch of errors in the exes and dlls. There is allready a fix it, but not official yet. You can download it at:
http://www.waldo.be/modules.php?name=Downloads&d_op=getit&lid=12
What you should do to create a new Navision 4.00 CD:
1) Copy CD1 on your hard drive
2) Overwrite the files with the files in this archive
3) Rewrite the CD
I hope MS will create a new release soon!
Enjoy!
Eric Wauters
MVP - Microsoft Dynamics NAV
My blog
  • eromeineromein Member Posts: 589
    your site isn't working waldo!
    "Real programmers don't comment their code.
    If it was hard to write, it should be hard to understand."
  • WaldoWaldo Member Posts: 3,412
    I can get on my site from all places I know ... plus ... the files have been downloaded about 20 times ... so I guess everything is working on my side ...
    Eric Wauters
    My blog
  • tvandongentvandongen Member Posts: 78
    Waldo,
    Could it be that your provider didn't publish his dns server in the right way. From the Netherlands you can only reach your site if I ad his dns server (dns.secondary.org, IP 68.46.140.152) directly to my network settings. Maybe it is only published in Belgium ?
    Thomas
  • Trevor_NorcrossTrevor_Norcross Member Posts: 29
    Worked for me in the USA
    Trevor Norcross
    SharePoint Implementation and Development
    Network Administration
    Mirifex Systems
    there's your answer ...
    The DNS question ... I wouldn't know. A friend is hosting this server (linux). I'll ask him when I get the chance ... .
    Eric Wauters
    My blog
  • itspeteritspeter Member Posts: 105
    The link is not working for me in Malaysia. :-s
    Peter Ng
  • rwabelrwabel Member Posts: 32
    for me neither in Switzerland.
    Paska Juttu ...
    Tested it ... approved it ... . Nothing I can do for the moment ... .
    Eric Wauters
    My blog
    I just changed some DNS settings. Please try again and let me know.
    Eric Wauters
    My blog
  • Rob_HansenRob_Hansen Member Posts: 296
    It errors out on me. :(
    Try again tomorrow ...
    Eric Wauters
    My blog
    Hi Waldo,
    It's working for me now. :D
    By the way, it's really a private website, need to make appointment. :lol:
    Peter Ng
    it works, thanks
  • Captain_DX4Captain_DX4 Member Posts: 230
    I attempted to apply these new files to correct the problem and I get a message back that the database and server versions do not match.
    Kristopher Webb
    Microsoft Dynamics NAV Developer
  • ajhvdbajhvdb Member Posts: 672
    :oops: well what do you think...you need to upgrade the client and the server
    sorry couldn't help it.
  • navisi0nenavisi0ne Member Posts: 36
    Hi Kristopher
    I had same problem cause I forgot to replace some files.
    You should verify to have the same version on server files:
      dbm.dll HotCopy.exe Nc_netb.dll nc_tcp.dll nc_tcps.dll SERVER.exe SLAVE.exe STOPSRV.exe
    and on client files:
      dbm.dll fin.exe finsql.exe nc_netb.dll nc_tcp.dll nc_tcps-dll SLAVE.exe
