MBS-Navision Developer's Toolkit v2.0 SP1
edited 2008-09-08 in Download section
Navision Developer’s Toolkit is designed to help you analyze, customize and update Navision applications. Regardless whether you are working as a Navision project manager, developer, supporter, trainer or sales person you will have to look behind the application.
http://www.mibuso.com/dlinfo.asp?FileID=394
    eperezeperez Member Posts: 8
    MBS-Navision Developer's Toolkit v2.0 support Navision Attain 3.60?
    AsallaiAsallai Member Posts: 141
    I always get an error message
    You do not have permission to run 'C/FRONT' System. Contact the system manager if you need to have your permission changed.
    I did step by step with the description...
    What should be the main problem? :?: Can anyone help me? :wink:
    jmjm Member Posts: 156
    Hi Asallai,
    see the DevTool Manual.pdf on page 92:
    Installing the Navision Developer’s Toolkit
    Before you start the installation procedure, make sure that you have checked the
    following requirements to install and run Navision Developer’s Toolkit:
    · Operating system Windows 98 or Windows NT/2000/XP.
    · Computer with Pentium processor.
    · Microsoft Business Solutions-Navision 4.00 or higher installed.
    · C/FRONT W1 4.00 or higher.
    · Microsoft Business Solutions-Navision license file (fin.flf) with permission to the
    granules C/FRONT and Navision Developer’s Toolkit available.
    especially the last requirement is important for you.
    br
    Josef Metz
    br
    Josef Metz
    Hi jm,
    My licence is contains access to the Object Designer, but only just limited object number.
    This DevTool is good for 3.7 too? :?
    Because maybe this is a main problem. In this case I misunderstood the whole thing, because I thought this version is good for the lower version number editions. But this is not, isn't it? :wink:
    Okay, thank you the help!
    Greetings.
    Asallai
    Timo_LässerTimo_Lässer Member Posts: 481
    The Navision Developer's Toolkit 2.00 (NDT) can also handle Database Versions <= 4.00 but it need a 4.00 database to store the informations. So Navision 4.00 must be installed.
    Further more you need C/FRONT for the access from NDT to Navision (<=4.00) and the special granule in your Navision license file (flf).
    Timo Lässer
    Hi Asallai,
    the MBS-Navision Developer's Toolkit v2.0 you can use for all
    textexport of Navision version 4.00 down to 1.20, also for 3.70.
    but your problem is that your licence must contain the
    granule 1.800 for C/FRONT and the granule 99.003.640 for
    the Navision Developer's Toolkit (Source Analyzer)
    and the granule 99.003.650 for the Navision Developer's Toolkit
    (Compare&Merge).
    br
    Josef Metz
    br
    Josef Metz
    Hi All,
    Thank you the information. :lol:
    I'll try to find another way to resolve my plan :wink:
    Thank you again!
    Asallai
    sc00bysc00by Member Posts: 43
    I've tried a few times now and each time I try, the download runs for a short time then blows out!
    Is it just me or is there a problem here?
    :roll:
    Rob.
    select * from users where clue > 0
    0 Records returned.
    emkproemkpro Member Posts: 47
    I have a license problem
    I cant run dev toolkit v1 nor v2 in my license file
    i have access to modules
    1,800 C/FRONT 1
    99,003,620 Developers Toolkit - Source Analyzer 1
    I still can not run dev toolkit it gives a permission error anyone has an idea what is wrong ???
    I have 99,003,620 but not 99,003,640 or 99,003,650 I couldn't understand why
    what 99,003,620 is for if not for dev toolkir ???
    As far as I know source analyzer is an extended license from compare&merge right ?
    //EMK\\
    jjanauskasjjanauskas Member Posts: 49
    You can't trust this tool [-X because it has many bugs when it will not find all the places where the object is used.
    For instance: try to find where a record 112 is used together with MODIFY. It will find several places where the MODIFY is called (directly, o indirectly, for ex. with WITH) for the record, but it will not find a codeunit 315 which is very simple and also calls "MODIFY" for T112.
    It also has many problems with finding where form controls are used and so on.
    So, be careful with it.
    Justas Janauskas
    Hi Justas,
    did you send a Service Request to MBS for thos error?
    br
    Josef Metz
    br
    Josef Metz
    Hi Jozef,
    Yes I did. Hot fix with this and others bugs is going to be released approximately in Q4 this year.
    Justas Janauskas
    nswausnswaus Member Posts: 12
    My Navision is Version W1 4.0 SP2(4.0 SP2). Could I use this tool kit?
    When I open database, it shows me "The database file cannot be used with this version of the program" and "Database Error: 1048".
    It means your database is created by either an older version or a newer versions of Navision.
    With version DTK2.0 Build 291 (the latest I think) you must use a 4.0SP3 DB. So first you need to create a DB with version 4.0SP3, export all (or the objects you want to check) as text and import it in the NDT.
    erwin_pherwin_ph Member Posts: 1
    Is there a new version of the developer's toolkit that can open nav50sp1 databases?
    thanks.
    NaviWorld Philippines, Inc.
    See the message posted above your question. There is no need for a newer version of NDT.
