Dynamics NAV Developer's Toolkit v3.01.410
The Developers Toolkit helps partners work faster and with accuracy, thanks to the direct link between the Microsoft Dynamics NAV development environment and the toolkit. While analyzing or upgrading Microsoft Dynamics NAV, you simply switch between screens as you work. Its well-laid out and color-coded graphical user interface gives you a clear, in-depth picture of all the elements you are working with, application code, and relations between objects.
The Microsoft Dynamics NAV Developers Toolkit, including tools for Source Analysis, as well as a Compare and Merge tool.
Version 3.01.410:
Compatibility to Microsoft Dynamics NAV 2009
C/FRONT DLL of Microsoft Dynamics NAV 2009 added.
Database objects of Microsoft Dynamics NAV 2009 added as backup (DevTool.fbk).
Skipping of Object Types
The object type PAGE will not be imported.
Skipping of Object Parts
The REPORT object parts RDLDATA and REQUESTPAGE will not be imported.
Table Property
The new table property FIELD GROUP will be imported.
http://www.mibuso.com/dlinfo.asp?FileID=1107
I can now import objects from our V4 SP3 system but the bug reported here - http://www.mibuso.com/forum/viewtopic.php?f=23&t=32184 - is still present ](*,)
It's a real shame this hasn't been addressed especially as it was introduced back when HF5 came out for V4 Navision ... 2-3 years ago!
Maybe one day [-o<
Rob.
i get an error if i want to do this (attachment)
I got the same error that "dayscott" reports.
I did what the "vaprog" said.
Now I got the error in attachment.
Can you help me, please?
I downloaded the NDT and installed it but I am also having the same problem with the 200-1 error in .stx.
Any solution for this problem?
I am using NAV 2009 SP1 Switzerland
Ovifo
EDIT: I downloaded the hotfix 31695, copied the cfront files and the fin.stx from .\Classic\ENU and it works
DevTool.exe crashes almost at the end of the merge process.
Already happened 3 times, any ideas?
Im using windows 7 enterprise edition x86
Source: https://mbs.microsoft.com/partnersource ... 009sp1.htm
RIS Plus, LLC
MVP - Business Apps
I´m excuting the merge process, and when arrive to Reports objects, program send an error saying "Database error : 1097" and they seems to continue, and is a reeeeeally slooooowly process (hours!)... but finally stop the merge process, near Report 702, and finally system froze.
After that, you can open de NDT DB, and I see was created tables and forms, but report just about 20.
Solutions? Can I delete some objects (think in reports) to finish correctly the merge?
So better just forget this pile of... code.
--Matrix
https://navurpo.blogspot.com/?view=classic
Because the server is secure (in theory), users can't run this programm without adding a GPO Software Restriction Policy for the DevTool.exe file.
So far this works, but after selecting the right database and account and password, the programm hangs and crashes.
I can't seem to find the reason for this, but I expect it has to do with the required GPO-SRP on this programm.
Tried to use systernal processmonitor and processexplorer but where unable to find the reason. Als the exenlog won't give any clue if a programm is unreadable.
The GPO-SRP isn't applied for the administrator account, and the programm works fine for the administrator.
Has anyone come across this same issue and were you able to resolve this?
Thanks for your reply.
Faulting application name: DevTool.exe, version: 3.1.0.410, time stamp: 0x00000000
Faulting module name: ntdll.dll, version: 6.1.7601.17725, time stamp: 0x4ec49b8f
Exception code: 0xc0000005
Fault offset: 0x0002ecaa
Faulting process id: 0xa54
Faulting application start time: 0x01cd8547b1d1fb42
Faulting application path: \Program Files (x86)\Microsoft Dynamics NAV\Developers Toolkit 3.01.410\DevTool.exe
Faulting module path: C:\Windows\SysWOW64\ntdll.dll
Report Id: 1f149a25-f13b-11e1-88b4-00155d007545
P.S. Resolved. the answer is yes, it can.
Try copying the fin.flf and .stx file from the NAV installation folder to DevToolkit installation folder.
With the help of friends I solved it. Problem is in regional setting (for date).
It is necessary to switch regional setting (Region and Language) to "English (United States)" - just for import.
Hi Thanks for the post,
I can't see C/Front folder, what am I missing?
Thank you for the valuable response!
Chowdary
I am not able to find the DTK to download the latest version.
where can I find it?
Thank you
Does anyone know if a compatible version with Nav 2013 is expected ?
The upgrading of the NAV developer's toolkit has been stopped some time ago.
Ops, simultaneous post :oops:
