Overflow in decimal
cbrandemanncbrandemann Member Posts: 4
edited 2008-11-28 in Navision Attain
During restoring a backup in Navision Attain I got an “Overflow in decimal” error. Due to a mistake in the C/AL-code a very great decimal amount (20.785.095.893.992.374,1) has been stored in the Navision Financial database.
My problem is: I can’t remove this great amount. I have tried a modify & delete without triggers. I got always the “Overflow in decimal” error. As had any of you a similar problem and how does you solved it? Or have you any idea for a solution.
Chris
  • i4tosti4tost Member Posts: 208
    Try to do backup if it is possible. Then restore in SQL and modify by using SQL tools.
  • AfonsoAfonso Member Posts: 27
    Try to do like this:
    First you retore only objects(threre is one option on the backup restore), and you change or comment the code wich is making the error;
    Second, restore the data information.
    Hope this helps,
    Afonso
  • cbrandemanncbrandemann Member Posts: 4
    Afonso wrote:
    Hope this helps,
    Afonso
    The error in the code has been solveld already. The problem is changing data in the database.
    :-) Thanks. Problem solved
  • lbadenaslbadenas Member Posts: 2
    I'm facing a similar trouble....
    How is it possible that navision native DB allows insertion of data that exceeds data type limit?
    I',ve never seen this before
    and it seems very easy to replicate the crash...
    just create a table with a decimal field
    then try to insert a value greater than 3.000.000.000.000.000 it shows an overflow exception.
    now create a Codeunit and make this codeunit insert.
    Something like this
    rec.index:=1;
    rec.dec1:=300.000.000.000.000 * 10;
    rec.insert
    No crash, even you can view the field if you run the table!!!!!
    =D> =D> =D>
    Incredible!!!!!!!
    any feedback about this?
    regards
    LLuis
