It is currently Wed Jun 19, 2013 7:27 am
Post new topic Reply to topic  [ 6 posts ]
 Post subject: Select Objects
PostPosted: Mon Sep 29, 2008 4:39 pm
Site Admin
Country: Belgium (be)
Select Objects
Often it is necessary to compare objects in various NAV-databases. You have the big group of objects in database 1. How to make the same selection of objects in a database 2?
With this tool you can do it in 4 simple steps:
1 Select objects in Database 1.
2 Copy, Paste in Excel and Save.
3 Run Form "Select Objects" in Database 2, fill all fields and click Select button.
4 Set Filter on the DBM Table No. of the Object-Table (Object Designer).
http://www.mibuso.com/dlinfo.asp?FileID=1013
 Profile
 Post subject: Re: Select Objects
PostPosted: Thu Oct 02, 2008 10:12 am
Country: United Kingdom (uk)
Oh sneaky, thankyou that's a very good idea.
But I expect you should make really sure that someone doesn't run it on native eg:
IF AllObj.GET(AllObj."Object Type"::Table, 2000000051) THEN ERROR('Really bad idea for Native');
_________________
Robert de Bath
TVision Technology Ltd
 Profile
PostPosted: Tue Feb 21, 2012 2:19 pm
Country: Ukraine (ua)
Hi all.
Who knows, for which purpose DBM Table No. field used? Which filter for this field I should use?
Thanks in advance!
 Profile
PostPosted: Tue Feb 21, 2012 5:22 pm
It's not used with the SQL server.
For the native (classic) database it's used in tabledata records to map the logical representation of Company name + Nav Table to a physical table within the database.
_________________
Robert de Bath
 Profile
PostPosted: Wed Feb 22, 2012 12:38 pm
Hi rdebath.
Thanks for fast answer!
So, as I understand, if I have database on SQL Server, I can leave filter blank for this field. But, I get error that it is must be greater than 0. What should I fill in in this field?
Thanks!
 Profile
PostPosted: Wed Feb 22, 2012 5:01 pm
Errm, you mean for this download?
It pops up a message for the value that it puts into the DBM Number field after the import. Or you could just use <>0
_________________
Robert de Bath
 Profile
Users browsing this forum: No registered users and 2 guests
