NAS Snap In error: mmc cannot intialize the snap-in
girish.joshigirish.joshi Member Posts: 407
Has anyone seen this error before when trying to add a snap in? This is for version 5.0
Microsoft Management Console
MMC cannot initialize the snap-in.
Name: Application Server for Microsoft Dynamics NAV Manager
CLSID: {50000003-0000-1000-0001-0000836BD2D2}
OK
    That happens sometimes when you use the console that gets configured by the NAS installer. Here's what I do, and this has never failed for me:
    - Start, Run, type 'mmc', hit OK. This opens a generic Microsoft console
    - File, Add/Remove Snap-in. This opens the list of snap ins
    - browse to the NAS one, and click OK.
    - I always add the event viewer, services, and computer management too
    - Click OK. Now the snap-ins should all be listed in the console window.
    - Save the console configuration with a name on your desktop, so you don't have to add reconfigure them again
    I've been meaning to write a blog about this for ages, maybe I'll find some inspiration soon
    I follow the steps above (my usual procedure as well) and received the same error....
    I was able to drill into the Application Server folder and run the NASMSnapIn.msc that exists there directly. However when I tried to instantiate it I received an error saying that the snap-in may not have been installed correctly.
    I didn't realize there were any special instructions for installing the snap-in...?
    kaelaakaelaa Member Posts: 28
    Hi there,
    try to install the visual c++ redistributable. it should fix it.
    I guess something iwasn't installed correctly!
    Hope it helps
    Did anyone find out why the issue occured? Is there a MS KB article on it?
    Follow Rashed's link, there are links to MSFT downloads in there.
    I followed the link -- but that's "just" the solution (thank by the way :) )
    Any idea why it may have happened?
    mmc uses a DLL that was not included with the installation.
    kylehardinkylehardin Member Posts: 257
    I encountered this problem after installing NAV2009 SP1 NAS on Windows Server 2008 R2. Installing Visual C++ 2005 Redistributable and its SP1 did not work either. The last post about it was missing a registered DLL got me thinking to just try registering them in order until I found the missing one.
    Go to the program files directory where NAS lives - the exact directory where nas.exe and nassql.exe live.
    I believe the only one that is required is NASM.dll, but I registered them all just in case. Some of them aren't controls so you will get an error message when trying to register them - that's OK.
    regsvr32 NASM.dll
    No reboot required - the NAS snap-in instantly started working.
    Kyle Hardin - ArcherPoint
